Tip & How-To about Computers & Internet
How to change your wireless network password. Forgotten wireless password.
Hi. Thanks for looking!
Due to the fact that many questions are being asked about routers and wireless networks I decided to put little tutorial together .
ยท How to change my routers password (forgotten password)
Since you forgotten your password and can not connect to wireless network you will need an Ethernet network cable in order to connect to router.
Before doing anything else switch your computer on and make sure that your router is on also.
1.
Connect Ethernet cable to your routers free port at the back and the other end to your PC/Laptop network port.
Once you get confirmation that you are connected to the network (you should notice this in the task bar right lower corner of the screen)
2.
Open your internet browser and type 192.168.1.1 in the address box and press enter. If this don'ttake you to the site asking for username and password please do the following.Click Start and choose run (below search) type "cmd" in the box and press enter.This should start a command prompt where you need to type in "ipconfig" and press enter. This should show you information's about your network. Default gateway address will be an address that you need to type in your browser box.
3.
Once you get to the login page, provide your username and password. You should be able to find this in your manual for router but if you can't you can find it hear--->click hear.
4.
Please note that since there's so many router vendors instructions in step 4 may vary, but these are basic.-
When you logged in to your router settings page please find wireless tab and choose security. Get to the password box and change password to whatever you like.
5.
Remember to save changes before quitting. Now unplug your cable and try to connect to your network wireless, using your new password.
Bravo! You just completed password change.
password change,no password, router password, router settings, no key, no connection, wireless password
Computers & Internet Logo
Hi im able to connect to te internet wireless with my computer but not on any other devise I need to get my security code, how can I do that?
Welcome to Fixya. If you want to connect to the Belkin Router Wirelessly and it is asking you for a Security Code, all you need to do is to access the router settings page and look for the Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
Thanks for using Fixya.
Apr 02, 2011 | Belkin Basic Wireless Router
from I read online need to reset my belkin router. How doi reset my belkin router so I can use my laptop. The model number is F5D7234-4-BC v1
In the back of every router there is a little hole that is used to reset it. Sometimes is just colored different and some times it says reset next to it. It would be the only one. Just use a pen or paper clip and push in gently so the little rubber depressor does not break and hold it in for 30 seconds(make sure you do 30 sec on a watch nut quick counting). Router needs to be ON when doing reset. Once reset is done you might have to disconnect power to it for another 30 seconds but only if your internet is not working. Hope this helps.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
i can not access my dlink system configuration using 192.168.0.1
Hi Thanks for your question. What you need to do is.
1. Click start and go to run 2. In run box put cmd 3. This should take you to the command prompt you need to type there ipconfig 4. You will be showed your network settings and your default getaway address is the address of your router 5. Type this address in your browser it should take you straight to your router site.
Good luck and please don't hesitate to ask more questions.
May 12, 2010 | D-Link DIR-300 Wireless Router
how do i put in my code am doing my setup and they ask me to go to my pc and enter the code on my tv screen.
Hi
To connect to wireless network you need to
1. Know the name of the network (provided by Internet Service Provider) and WPA pass phrase.
2. Make sure that wireless connection on your PC is enabled
3. Once your router is switched on you should be notified by your computer that wireless networks are available.
4. Click Start---> Connect to---->Wireless network
5. Click show available networks and choose your network
6. Click connect and PC should ask you for password put the password in the box and confirm.
7. By now you should be connected to the network
If you find difficulties setting this up please do not hesitate to ask more questions. I will be more then happy to help you. Good Luck
May 01, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Living in Bulgaria. Comp. connected to dish. Netsurf. Using wireless network. Comp. on / off all day and eve. Comes on screen, limited or no connectivity. You may not be able to connect to internet. Also flashes up, this problem due to the fact that the net work did not assign a network Address to the computor. What is all this,? and can you advise in simple terms of how it can be rectified. Driving me nuts. Thanks, John. Sig. good.
try Static IP and DSN address
it looks like you have router setup issue where you are timing out
go to setup option and change this to connect with 9999
not sure of your router but most of the router has this setting
also try upgrade or update new firm ver and reboot router
let me iknow if this does not with router make and model
Apr 26, 2009 | Computers & Internet
1,627 people viewed this tip
David Payne
David Payne
