Tip & How-To about Computers & Internet
Configuring Belkin routers without installation CD for Cable ISP: ·
Configuring Belkin routers without installation CD for Cable ISP :
  • Connect the cable Modem/ Ethernet cable from ISP to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:Check for the internet status at the top right hand corner. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
If it is not connected then we need to configure by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next.
Step 3: HOST NAME leave it blank or you can type anything there and click on APPLY CHANGES.
Step 4: Click on MAC ADDRESS or MAC CLONE (found right below the connection type on left side of RSP).
Step 5: click on the button CLONE (once you click on clone the MAC address will get changed) and click on APPLY CHANGES.
Step 6: Before doing MAC clone one important thing has to be noticed. Check whether you are able to go online when you connect the computer directly to the cable modem. Because Cable ISPs uses a particular kind of authentication called MAC authentication. Hence, only the particular computers whose MAC addresses are registered in their database will be able to go online directly from the modem.
***MAC clone is a feature that copies the MAC address of your computer and pastes it in the router. So the router will have the MAC address of your computer and it will get connected to the internet.
Step 7: Now check for the internet status at the top right hand corner. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
  • Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
  • If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected.In this case you need to repeat the above Network power cycle by unplugging the cable that is going into the cable modem from the wall outlet.
  • Still if the internet status is not connected, then connect your computer directly to the modem and check whether you are able to go online.
  • If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
your wired part is configured completely now.To configure the wireless part click here
Computers & Internet Logo
how do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
haw can i install Belkin wireless router N300 without the CD
You can easily follow the following steps to install it without a setup CD
Step 1: Please find a compatible power source and plug your modem into it.
Step 2: Now, you can connect your computer to the modem using an Ethernet cable without the router being installed.
Step 3: please verify whether your computer is receiving an internet connection or not. Just click and access any website of your choice.
For more details kindly visit How to Login Netgear Wireless Router Routerlogin net
Apr 10, 2012 | Belkin F5D7234-4 Router
I have a Huawei EC 168 usb modem from alltel and would like to know if it can be used with my belkin N+ router
inorder to connect to the belkin router you should have an ethernet outlet from the modem...even if it is an usb modem, go ahead and check whether there is an ethernet port...if there is an ethernet port, then connect it to the MODEM port of BELKIN router using an ethernet cable...if no ethernet port is found then it willnot be possible to connect to the belkin router...
because belkin router has got only ethernet port for getting connected to the ISP...
pls rate me if its useful...
Apr 03, 2010 | Belkin Computers & Internet
how to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
1,571 people viewed this tip
David Payne
David Payne
