Tip & How-To about Computers & Internet
Windows problems connecting to WPS enabled routers
You may come across connection problems when routers have Wi-Fi Protected Setup (WPS) enabled and clients do not support it.
In Windows XP, Wireless Zero Configuration (WZC) may mistake a WPS enabled router for a WPA-Radius protected one and warn you that there is no certificate to connect to it:
To work around this problem, you can either disable 802.1x authentication on the client or disable WPS on the router's.
802.1x on the client can be disabled in the properties of the wireless network. On the Authentication tab, untick the 802.1x Authentication option. Make sure that the correct encryption type is selected on the Association tab and that the WPA Pre-Shared Key or the WEP key is entered.
On Windows Vista things may even be worse. When you try to connect to a WPS enabled network, Vista may prompt you for a user name, password and domain name as if PEAP authentication were used. When you manually create the network profile specifying WPA2-PSK, AES and the Pre-shared Key, Vista may refuse to connect stating that the network profile does not match the actual configuration. The only work-around in this case is to disable WPS on the router.
To disable WPS on the router, go to the Wi-Fi Protected Setup.
To learn how to disable WPS click here...
At the top of the page, just set WPS to disabled and apply changes. You may need to delete the profile for the network on the client card before it can connect to the router.
Computers & Internet Logo
What is WPS button?
The WPS is abbreviation for Wi-Fi Protected Setup. This function should you help to set up strong wireless network password (so called "shared secret") by very easy way.
For most of users is very hard to create, remember and assign complex long password to Wi-Fi router and client devices e.g. smart phones, laptops, printers.
Short and simple (non-complex) password is weak and can be broken by hackers. You can set strong password using WPS buttons. No device management access is required.
Procedure description
Press WPS button on both devices you wish connect each other. (Router, wireless printer...)Wait until password is set automatically and devices are connected.There exists second procedure in WPS standard. It is similar to described one, but PIN number is required in addition.
Security warning!!!
Enabled WPS function is very high security risk. The WPS sets strong password, but offers another security hole to hackers. The WPS standard is affected by well known vulnerability and therefore is insecure. It is recommended to DISABLE WPS ON ALL DEVICES. Go to device setup and disable the WPS completely.
Jan 28, 2016 | Computers & Internet
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
Where is wps on Belkin n1 vision?
Before you will be able to use this function, you will have to log into your router and enable WPS push button in the security settings.
PBC: Push and hold the WPS button located on the back of your N1
Vision for three seconds. Then, initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WP
Aug 21, 2013 | Linksys WRT160N Wireless Router
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
3,617 people viewed this tip
David Payne
David Payne
