Tip & How-To about Computers & Internet
How To Connect To The Cloud ?
In order to connect the Skype phone to the Cloud you need to register the units MAC address.
The MAC address can be found by selecting Menu, Settings, Information. It is also located under the battery of the Skype phone.
Once you have made a note of the MAC address visit http://www.thecloud.net/belkin.
Here you will then find a link to sign up. To connect to the service will cost £6.99 per month, however you will receive a 30day free trial prior to being charged. Once you have signed up and registered you will then be able to connect automatically by connecting to the wireless network "Wifi Zone - The Cloud" wherever available.
Note that this information is subject to change....
Computers & Internet Logo
How do I receive my kindle books when my email address is different?
I assume you mean kindle books you order online (not from the kindle itself?)
They are delivered to your Kindle based on what you have registered on line, not to your email. Therefore changing your email address should not matter (at least directly).
When you say 'moved' - do you mean moved house physically (which does not matter at all) or moved to using a new kindle? Assuming you mean a new kindle, you need to
A) make sure the kindle is registered to your Amazon account: go to home screen, touch top of screen to bring up menu and then press the 'three lines button', select settings. There should be option to register (you will need email address and password - so you need to make sure your online Amazon account has correct email address registered! This is where email change might be causing problems, but can be updated online)
B) when you order books online you need to select the correct kindle to deliver to in the drop down box next to the order button (it might be called something like "Paul's Second kindle")
You can access all books you have ever bought (for this kindle or any other) on Kindle paper white by selecting 'cloud' when on the list of books at home screen.
Hope that helps, if not please reply and explain in more detail what you are doing and what happens / does not happen
Jan 06, 2015 | Amazon Kindle Paperwhite
how do i find the mac address
    Follow these instructions to find the MAC Address of your Android phone or tablet:
    • Press the Home button at the bottom of the phone.
    • Press the Menu button.
    • Tap Settings.
    • Tap Wireless & Networks.
    • If Wi-Fi is not already selected, tap Wi-Fi to turn it on.
    • Press the Back button.
    • Tap About Phone.
    • Tap Status.
Oct 06, 2014 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
i can't get my chromebook to print to a my HP printer
Are you using the Google Cloud Print? If you are, you need to install a software called proxy, as part of the Chrome OS. The proxy will register the printer with the service.
Printer turned on? Classic printer installed on another computer?
When you first connected your printer to Google Cloud Print, you had to use another computer to enable the Google Cloud Print connector. Is the computer you used to enable the connector turned on? are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or Chrome user account you were using when you connected the printer with Google Cloud Print.
If using a cloud ready printer; are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or
Delete the printer and reconnect the printer with Google Cloud Print. Are there duplicate printers on your Google Cloud Print page?
In Google Chrome, select Options > Show advanced settings > Sign out of Google Cloud Print.
Visit the Google Cloud Print page and click on Printers. Delete any duplicate printers (printers with the exact same name) and then sign in to Google Cloud Print again to print.
Nov 24, 2013 | Samsung Chromebook Xe500c21 12. Led...
how do i find out what my mac and ip addresses are?
Windows XP
  • The host name is your computer's name
  • Click the Start icon
  • Click Control Panel
  • Select Classic View
  • Click Network Connections
  • Right click on the connection you are trying to find the MAC address for and select Properties - you will have a separate MAC address for your wireless card and your Ethernet (LAN) card. Make sure you use the correct one.
  • Hover your mouse over the text box underneath connect using. Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your computer on AU network you will need to register this MAC address
Apple Mac OS X (Tiger)
Information Services does not provide support for the use of Apple Macs. However you may find the following instructions useful if you wish to use your Apple Mac on our network
  • From the Apple in the upper left hand corner choose System Preferences
  • Click on the Network icon
  • From the Show menu Select Airport (for Wireless) or Built in Ethernet (for Wired)
    • For the Built in Ethernet (for Wired) the MAC address will be at the top of the Ethernet tab as the Ethernet ID.
      The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
    • For the Airport (for Wireless) the MAC address will be at the top of the AirPort tab as the AirPort ID (or on the TCP/IP tab, again as the AirPort ID ). The MAC address is the 12 character address e.g. 00:14:67:F0:56:A4
  • To find your Computer Name go back to System Preferences and click on Sharing , your computer's name should be in the computer name box at the top of this window.
Apple Mac OS X (Snow Leopard/Leopard)
  • Select Ethernet for Wired or Airport for Wireless
  • Click on the Advanced button
  • Click on the Ethernet tab
  • Your MAC address will be at the top of this window as your Ethernet ID . The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
Linux
  • In a privileged terminal session type: ifconfig
  • This will show you a list of the network adapters installed. The MAC address is referred to here as the HWaddr
  • If you have a wireless card you will see more then one MAC Address, make sure you register the right MAC address.
  • To pick out your wireless MAC address type: iwconfig - your Wired one will be the other one
Vista
  • Click Network and Sharing Center
  • Select Manage Network Connections from the list on the left hand side
  • Hover your mouse over the text box underneath connect using . Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
Windows 7
  • Select Network and Internet
  • Select Change Adapter Settings from the list on the left hand side
    You will have a separate icon for your wireless card; your Ethernet (LAN) card and your Virtual WiFi MiniPort adapter (if you have one), each with their own MAC address. Make sure you select the correct one.
Nokia mobile phones
  • On the home screen, enter *#MAC0WLAN# or *#62209526#
  • Your MAC address will appear as a popup and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your phone on AU network you will need to register this MAC address
http://whatismyipaddress.com/
You can use this link to find out your IP address
Good Luck
Dec 06, 2010 | Computers & Internet
media access crontrol (MAC) address
Hi Stevetabor9,
Finding and Registering Your Xbox Console's MAC Address
  1. Turn on your Xbox console with no game disc in the disc tray.
  2. From the Xbox Dashboard, choose Settings, and then Network Settings.
  3. The 12-digit number at the bottom-right corner of theNetwork Settings screen is the MAC address of your Xbox console. Do not change your Xbox console MAC address; just write it down so that you can use it later.
  4. If you have a direct connection from your Xbox to your modem, you'll have to disconnect it and reconnect your PC to access the Internet.
  5. From your PC, open the following page:
    British Columbia: http://oca.bc.hsia.telus.net
    Alberta: http://oca.ab.hsia.telus.net.
  6. Log in using your Telus Velocity Internet Service account.
  7. Select Manual Registration and Administration of PC's and Devices.
  8. In an available slot, enter the MAC address of your Xbox console, then select Update.
  9. Follow the steps in Direct Connection with Telus to try to connect to Xbox Live again.
Registering Your Router MAC Address
  1. See your router documentation to find your router MAC address.
  2. Before disconnecting your PC from the Internet to set up a router connection, open the following page:
  3. Log in using your Telus Velocity Internet Service account.
  4. Select Manual Registration and Administration of PC's and Devices.
  5. In an available slot, enter the MAC address of your router, then select Update.
  6. Set up a router connection to Telus and try to connect to Xbox Live again.
take care
Mar 15, 2008 | 2wire 2700HG-B Router (2700HGB)
657 people viewed this tip
David Payne
David Payne
