Tip & How-To about Computers & Internet
What type of headset can be used with the Skype Phone?
Both version 1 and 2 of the The Skype Phone use a standard headset with 2.5mm jack size, similar to ones used for Mobile Phones. The headset needs to have a microphone as well as a speaker.
Members of Skype fora tend to recommend the use of the Senheiser MM30 or the Plantronics M214i
Computers & Internet Logo
headset size for samsung sw531 mobile phone
Hi brentcopeman,
U would say yes this is the case. Nearly all mobile phones have a 2.5mm headphone jack up to the newest smartphones and walkmans that have been in production on the last year or 2 some of which use the standard headphone jack size.
I might add that if you have headphones that you like already to buy one of these:
http://www.amazon.com/Headset-Adapter-3-5mm-2-5mm-Converter/dp/B000LMBJMA
That way you can use the headphones you already have and insert them into the phone using the adapter and don't have the added cost of new headphones unnecessarily.
Hope this helps you out.
Dec 14, 2011 | Audio Players & Recorders
Skype microphone stopped working
if u have another mic in (front or back of computer) try the other one, if not working try to swap the audio device - in skype /option/ audio setting
daniel
http://rylwy.com/
Jun 17, 2009 | Skype IM
vtec 7100 won't connect to skype
1. Unplug and re-plug the usb cable from the base station to your Skype computer.
2. Make sure Skype is running.
3. Re-install the vtech software (you can download it at http://www.vtechphones.com if you need to)
4. When Skype asks if it's ok to let it connect, do that.
Apr 04, 2009 | Vtech CS5111-2 Twin Phone
how do you program phone for headset mode on sts phone and where do you plug it in?
Some phones have jack on the side of the phone. If it does not, you will need a standard telephone headset with amplifier. You will need a handset button (634) programmed on the phone. Then in programing Flash 50 button 4 you will need to disable speakerphone. Flash 50 button 18 determines the headset type: 0-is amplified unit plugged into handset cord, 1-is 2.5mm jack on side of phone,
To use handset, press handset button so it is lit, use on off to answer calls with the handset.
Mar 05, 2009 | Vodavi IP7024LD Corded Phone
429 people viewed this tip
David Payne
David Payne
