Tip & How-To about Audio Players & Recorders
How to dry an mp3 / mp4 device thet you spilled water on or dropped in water !
Don't lose hope yet!
You should do the steps bellow as soon as possible.
-Disconnect from outlet (if connected).
-Remove the battery (if possible).
-Dry it with a towel.
-Cautiously! with a hairdryer blow it dry! even inside the compartment, if you have access. Have patience! keep on for few minutes!
-Putting in raw rice for a day or two can help to dry it further.
Even if these steps do not help to revive it, they will definitely maximize your chances for your device to be accepted by the manufacturer to be repaired under warranty/guaranty!
Bruce
my camera wont turn on.
This problem occurs when your camera has weak batteries or the wall outlet is not working. Try to change your batteries or just try another wall outlet for adapter/charger. Also, make sure that the battery is inserted properly.
You could also follow these steps:
Check batteries -> Connect camera to an AC adapter -> Remove all batteries -> Disconnect AC adapter -> Wait 2-3 minutes -> Reinsert batteries -> Reconnect adapter -> Turn on your camera.
I hope it works! Give it a try. If it won't work, contact the firm that produces your model of camera.
May 19, 2011 | Cameras
296 people viewed this tip
 Grubhead
Grubhead
