Tip & How-To about Audio Players & Recorders
The CD/DVD/Blueray player remains on "loading" state after putting a disc in!
With some luck, you might be capable of fixing it yourself without even opening the box!
-Try to push the tray in a little bit when closed! Some times dust gathers on the greasy tray rails resulting it not to open and close to the full extend. If it helps but the problem comes back, then you should open the box and clean the the rails more thoroughly. Have a look at the switch that senses if the tray is open or closed. (Placement is model deppendant ) !
-Clean the optical lens with a cleaning CD(It is a disk with a soft brush glued to the readable side close to its center). If you haven't got one you could try to blow inside with a straw while the tray is open.
If these don't help then you must open the box.(If you are kind of a handyman) or let a pro do the job.
Unplug the box from wall outlet.
Open the box then check all the cables that go between the DVD unit and the PCB/electronics board. You may "Carefully" disconnect the cables from both ends then reconnect them (Some times cables themselves could be causing the problem).
If none of the above helps it most likely is the laser-/optics-head that has burned out and needs to be replaced. Other electronics failures are possible too but rare. You may consider getting professional help!
God luck!
Bruce
The tray is stuck open and will not retract. Unit appears to think it is closed but will not pull disk tray in.
This was a common problem for Toshiba sets a while ago, but was fixed by an engineering change. What is the make and model of your unit? With the power off, try to push in the tray a little bit (DO NOT FORCE IT!!) With the tray partially in, plug in the set and turn it on. The tray should close. If not or if the tray opens fully, then there is a problem with the position switches inside the set. These are small leaf switches that can get dirty or break. On a power up, the tray should retract to the "loaded" position.
Please update this with more details.
Thanks,
Dan
Nov 10, 2010 | Televison & Video
dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Nov 25, 2007 | Panasonic 600W DVD+VCR Home Theater System...
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
my xbox 360 disc tray wont open how do i fix that problem
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Sep 19, 2009 | Microsoft Xbox 360 Console
649 people viewed this tip
 Grubhead
Grubhead
