Tip & How-To about GPS
Motonav TN20 Firmware Fix
Motorola Motonav TN20 Firmware Fix
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
_______________________________________________
Motorola Motonav TN20 Manual Download
Motonav TN20 Upgrade Manual
Motonav TN20 Firmware Download
GPS Logo
This tip sucks! You got my hopes up that you actually had the update file to download. What a waste of time. The motorola site is just as worthless for getting the update
May 06, 2010 | Motorola Mobility MOTONAV TN20 GPS...
2,431 people viewed this tip
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
