Tip & How-To about Washing Machines
How to keep your new high efficiency washer clean
Start by reading your manual. 99% of folks never do. Less is more with products like detergent, fabric softener and bleach. Because your machine uses less water and has a different theory of operation than a standard top loader, special care must be taken to use only HE detergent, and the smallest amount for the soil content in your load. Fabric softeners build up and accelerate mildew growth, so use sparingly. Wash your machines gasket after you are done with your machine for the day with a paper towel and check under the little flap for any objects you might have missed in pockets or buttons.
Monthly run your machine thorough with hot water and EITHER white vinegar (1 qt, in the detergent dispenser) OR 1 cup chlorine bleach, same place, or you can buy washer cleaners like Affresh tabs or Tide washer cleaner.
The important thing is to leave door ajar to facilitate air flow.
Washing Machines Logo
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful gummy residue in my sink where the water dischargers, YUK. My sister in Fla just bought a Frigidaire front load and she was told to use 1 Tablespoon of this special powdered detergent and no fabric softner should be used. What is that about. I am totally confused, never had any problem like this with my top load machine. Help please, don't want to ruin machine or my plumbing. Thank you. Norma Goodman, 21 Belmanor Dr, Rochester NY 14623
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
just purchased daewoo washer DWD-WD1353RC..it seems the fabric softner is not dispensing and the detergent is barely used. I understand this machine usesHE detergents but it is using very little detergent and not at all the fabric softner. Is there anything I can check to make sure nothing it wrong with fabric softener dispenser?
this washer has different detergent concentration levels settings. 1.By holding delay wash then power button at the same time, while unit is off. then a C1,C2,C3 are main detergent concentration settings C1 being regular HE detergent and C3 being very concentrated some detergents tell you X2, X3 S1,S2 are softener B1,B2 are bleach 2. Then use buttons Delay wash to scroll for main detergent Extra rinse for softener Bleach for bleach 3. power button to exit and confirm
hope this helps also in manual and to clean tanks, Manual says to call a 1800# or find the instructions on the web. I've had this washer for a week no problems yet
Jan 31, 2011 | Washing Machines
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
278 people viewed this tip
Top Washing Machines Experts
