Tip & How-To about Computers & Internet
Windows 7 Drivers for Printers and other accessories
As it is known to everyone that Win 7 is the latest Operating System from Microsoft and that lacks one of the best thing which Windows XP was having embedded inside it. Yes the in-built drivers which were automatically detected and installed without any rush for chasing drivers. Till date there are many computer peripherals like (printers, scanners, webcams, tablets, sound cards, NIC or Ethernet or LAN card, laptop, notepad GPS devises, Routers, Switches, Modems, Mobiles and many more) for which MS has not yet released the drivers or the publisher has not yet released drivers for Win 7. Hence,ultimately the user is suffering as they cannot use the peripherals which they were able to use with XP but after installing Win7 those devices don't work anymore because of the lack of drivers inside Win7 Operating
System.
The good news
Win 7 has a very good feature inbuilt on this problem that is compatibility driver installation mode. One can try and install the existing Win XP driver in Win7 with compatible mode. If an XP driver is installed in Win7 with compatibility mode then that particular peripheral gives out the efficiency upto 90% .
In order to install the driver first connect the device to pc and then select have disc in the wizard which pop-ups and then follow the wizard and look out for the word compatibility mode. Just select compatibility mode and your device isready to be used in Win 7. Otherwise you can also install the driver through control panel add new hardware and simply select have disc instead of search automatic and don't forget to select compatible mode while following the wizards instructions.
Computers & Internet Logo
Can I install Service pack 3 for windows 7 for free?
Win 7 does not have a SP3. The latest is SP1. You might be thinking of XP, which is not supported by MS any more, although you can get SP3 for it on the Net.
If you do have Win 7 go here
http://windows.microsoft.com/en-AU/windows/service-packs-download#sptabs=win7
May 05, 2016 | Microsoft Windows 7 Home Premium 64BIT...
My firefox will not allow me to open facebook login
If you're using Microsoft Windows XP Pro or any variation of XP for that matter, you more than likely have a virus that is creating this problem for you. Windows XP is a dead operating system. They quit providing update support, internet support and virus/malware support for that system. I know it sucks... XP was one of my favorite operating systems as well but now I have upgraded to Microsoft Windows 7 Professional. Your best bet is to do the same. I'd recommend Win 7 as opposed to Vista or even Win 8 but it's all in preferences... The choice is yours to make overall. I hope that this helps :-)
Apr 05, 2015 | Microsoft Windows XP Professional
nancyladwig@gmail.comlogin my gmail account
It will be best to load the computer with Win-7; rather than loading Win XP; as update support to Win XP is not in air since 5 months. Microsoft have stopped the update.
Load it with Windows-7 Ultimate. It is the best O/S.
Gopakumar Gopalan Google
Aug 07, 2014 | Microsoft Windows XP Home Edition
i am using toshiba l310 laptop with windows xp installed onit.NOW I WANT TO CHANGE MY OPERATING SYSTEM FROM XP TO WINDOWS 7,MY QUESTION IS THAT CAN I USE SAME DRIVERS FOR WINDOWS 7 WHICH I USE ON XP O-SYSTEM.PLZ SUGGEST ME WHICH OPERATING SYSTEM IS BETTER XP OR WIN 7.WHAT IS THE BASIC DIFFERENCE BETWEEN THE TWO. THANKS
You will need new drivers for Win 7. Before attempting to go to Win 7, run the Microsoft Upgrade Advisor and see what issues it lists: http://go.microsoft.com/fwlink/?LinkId=161223 (since laptops have on-board video that may be an issue). You will be doing a custom install from XP and have to reinstall all of your programs and drivers - many will be available. Several XP programs will not install in Win7 without some work (compatability mode or the XP mode virtual machine (in Pro or Ultimate). Upgrading your software may be needed unless you have the latest version that supports XP through Win7 or want to do the work-arounds.
In addition you would be wise to check for any BIOS updates for your specific machine and apply those. Windows 7 is a good OS if you have 2 GB or more of memory. It can run with less but it isn't better than XP in that case. The biggest difference is that Win7 will be supported by Microsoft for updates for a longer period (patches); XP will lose that support in the next few years.
I hope this helps.
(I converted an XP desktop to Win7. However, my video card could handle the OS and I have 2.5 GB of memory and a Windows Experience Index of 3.9 from the system.)
Feb 15, 2010 | Computers & Internet
162 people viewed this tip
David Payne
David Payne
