Tip & How-To about Plumbing
Removing old faucets under sink.
I had to change out a faucet under the sink, it was a marble top and couldn't be moved, so I had to get up under there with one of those wrenches that are supposed to grab the nuts and spin them off?? Well, That didn't work, and I couldn't turn it with my hands. and I couldn't get in there with anything. So, I got a piece of 1 inch pvc pipe, schedule 80, with the band saw, cut a slot in on side for the supply line and cut a smaller slot in the other side for the wing on the nut, it went up and turned the nuts off the supply line and the nuts off the bottom of the faucet no problem, worked great. I even put the thing in the tool box for future use.
Plumbing Logo
Kitchen faucet
You will need a basen wrench ( a special wrench to tighten nuts that secure faucet to sink) and open end wrenches. First shut off both hot and cold water valves. Using open end wrench, disconnect hoses from valves. Now, you must loosen both nuts (under the sink towards back wall) Using the basen wrench. After removing nuts, lift faucet up
Jan 09, 2014 | Plumbing
loose faucet
Tighten Faucet from under the sink.
Nov 14, 2013 | RTO Classic, Circular, Blonde, Solid...
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: FortĀ® Single-control...
The unit has a croosbar connecting the hot and cold water. How do you remove the crossbar to replace the faucet
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
May 21, 2009 | Delta Faucet 2520 Classic 4'' Centerset...
296 people viewed this tip
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
