Tip & How-To about Computers & Internet
Speed/tune up windows vista
Not all steps are mandatory !!!
1. Turn off Windows Search Indexing
Windows Vista search indexing is constantly reviewing files on your system to make their contents available for quick searching. This is handy, but can severely impact system performance.
To disable this constant indexing:
Click Start then Computer
Right Click the C: Drive
On General Tab, Uncheck Index this drive for faster searching
On the subsequent dialog box, Select Include subfolders and files
2. Turn off Remote Differential Compression
Remote Differential Compression measures the changes in files over a network to transfer them with minimal bandwidth rather than transferring an entire file that has previously been moved. By constantly checking for file changes, this service can hinder system performance.
To disable this service:
Open Control Panel
Switch to Classic View
Select Program Features
Choose Turn Windows features on and off
Scroll down and uncheck Remote Differential Compression
3 Turn off Automatic Windows Defender Operation
Windows Defender real-time protection against malware continues to run despite having Automatic operation disabled.
To disable this feature:
Open Control Panel
Select Windows Defender
Choose Tools from the top menu
Select Options
Uncheck Auto Start at the bottom of the window
5. Turn off Automatic Disk Defragmentation
Windows Vista and its always-on defragment feature isn't really that necessary and can cause system slow down. Just remember to run a defrag manually every week or so.
To disable this:
Select the Tools Tab
Uncheck Run on a schedule
6. Add a 2GB or higher USB Flash drive to take advantage of Windows Ready Boost (Additional Memory Cache)
Ready Boost is Microsoft's name for using a USB thumb/flash drive to provide some quick access memory the operating system can use as extra RAM. The Ready Boost system can significantly improve system performance.
To set this up:
Insert a USB Flash Drive (preferably 2GB or more)
Right Click the USB Drive in My Computer
Select the Ready Boost Tab
Choose Use this device
Select as much space as you can free up for RAM usage vs. Storage
7. Turn off Windows Hibernation
Windows hibernation background services can use a large amount of system resources. If you don't use the Hibernate feature on a regular basis you may want to disable it to give Vista a performance boost.
To disable Hibernation:
Select the Control Panel then Power Options
Click Change Plan Settings
Click on Change Advanced Power Settings
Expand the Sleep selection
Expand the Hibernate After selection
Crank the selector down to zero
Click Apply
8. Turn off System Restore
Analysis and restore point creation by Windows Vista can eat a fair amount of system resources. Disabling this service will obviously mean the system restore feature in Vista will not be available in the event of a system crash. Change this at your own risk.
Control Panel>System
Click System Protection on the left panel
Uncheck the main system drive
Agree to the confirmation
9. Disable User Access Control (UAC)
10. Disable excess Windows Services that Auto-Launch at Startup
Just like Windows XP, Vista ships with all kinds of services enabled that load at startup and may never be used by most users.
To see what loads at startup and disable the ones you likely won't be needing (they can always be started manually later):
Click Start then Control Panel
Select Administrative Tools
Choose System Configuration
Click the Services Tab
You can safely deselect:
Offline Files (unless you're using Offline File Sync)
Tablet PC Input Service (unless you have a tablet PC)
Terminal Services
Windows Search (If you have already disabled indexing)
Fax (unless you're using a fax modem)
11. Disable Excess Windows Features
Windows ships with other features that are listed separately in the Vista operating system from the startup services.
You can view and disable these features by:
Clicking Start then Control Panel
On the left panel, select Turn Windows Features on or off
Indexing Service
IKE and AuthIP IPsec Keying Modules (Disable) VPN service stuff
IP Helper (Disable) Until IPV6 is commonly being used----it's worthless
IPsec Policy Agent (Disable) Not many Internet Providers require this---mine doesn't.
KtmRm for Distributed Transaction Coordinator (Disable) High level networking
Remote Registry (Disable) I really don't want someone else in my Registry, remotely!
Secondary Logon (Disable) No need----I'm the only logon----ever!
Security Center (Disable) No need if you are running another Security Program
Tablet PC Optional Components
Tablet PC Input Service (Disable) I don't have a tablet PC!
Windows Error Reporting Service (Disable) I don't want to inform MS of errors.
Windows Media Center Extender Service (Disable) Unless you hook to an X-Box.
Windows DFS Replication Service
Windows Fax & Scan (unless you use a modem for faxing)
Windows Meeting Space (unless you use the Live Meeting Service)
Windows Firewall (As long as you are running another Firewall)
Windows Search (If you never search the internet without your browser)
12. Stop Security Notifications
You must do this BEFORE you disable the Security Center Service. In the Notification Area which I call systray (bottom-right where the time is), right-click on the Security Shield and choose Open Security Center. On the left choose Change the way Security Center alerts me, then choose Don't notify me and don't display the icon. The shield will disappear.
13. Disable Windows Vista Sidebar and prevent it from running at Start-up
Right-click in the Sidebar area and choose Properties. Then uncheck Start Sidebar when Windows starts. If you want it back for some reason---You can start it any time by simply typing "sidebar" in the search bar of the start menu. This one is a big memory user and WILL slow things down on a normal machine. I found it fairly useless.
14. Speedup Start Menu Search
Start Menu Orb >>>>Run>>>>type in regedit
HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Explorer/Advanced.
Find and right click on Start_SearchFiles and select Modify. Set the Value to 0.
Don't reboot yet till you have done Step 6
15. Speedup Menu Display
HKEY_CURRENT_USER/Control Panel/Desktop
Select MenuShowDelay from the settings on the right
Set Value to 200 (I find 0 way to fast...)
Reboot
16. Do an Advanced Disk Cleanup
Start Menu Orb >>>>>Run, type: cleanmgr /sageset:50
Select the options you want, I think it is fine to choose them all. Click OK and close out the window. (there is a space between the r and the /)
Start Menu Orb >>>>>Run, type: cleanmgr /sagerun:50 (there is a space between the r and the /)
Computers & Internet Logo
Search box is not in start?
Your index requires virtually no maintenance. However, if the index has problems finding files that you know should be located in an indexed location, you might need to rebuild the index. This can take a long time to complete, so avoid performing this step unless you have given the index enough time (several hours) to correct any problems first. To rebuild the index:
1. Open Indexing and Search Options by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Indexing Options.
2. Click Advanced, click the Index Settings tab, and then click Rebuild. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
OR
Select Troubleshoot a problem from the taskbar and type in search field: Windows search. Then select Search and Indexing and use the wizard to fix the problem.The search service was not started. Worked for me
Nov 11, 2013 | Advent Computers & Internet
Indexing service doesn't work.
IF you have a full genuine copy of windows, check the microsooft knowledge base.
IF you have a cracked/copied version, it may be of an earlier build, not the final version. This may be the problem you have.
THis may also be a virus/malware infection. Scan for both in safe mode
Jul 21, 2010 | Microsoft Windows Vista Ultimate Edition
constant hard drive noise on j2489
Are you using Vista? If so that's your problem, Vista is constantly scanning your hard disk for indexing. To turn it off follow this link: http://4sysops.com/archives/how-to-disable-vista%E2%80%99s-desktop-search-indexing-windows-search/ but bear in mind that search etc will be much slower, and some things in Vista may not work the way they're supposed to as it is now an integral part of the OS.
Aug 04, 2009 | Computers & Internet
2,112 people viewed this tip
David Payne
David Payne
