Tip & How-To about Computers & Internet
How to solve Internet Explorer 8 installation problems
Method A: Reset Windows security settings back to the defaults
Restore the security settings to the default settings.
To fix this problem automatically, click the Fix this problem link which is in the article 949220 Then click Run in the File Download dialog box, and follow the steps in this wizard.
1. Click Start, click Run, type cmd, and then press ENTER.
2. In Windows XP, type the following command, and then press ENTER:
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
In Windows Vista, type the following command, and then press ENTER:
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose
You receive a "Task is completed" message and a warning message that something could not be done. You can safely ignore this message. For more information about this message, see the %windir%\Security\Logs\Scesrv.log file.
Next steps After you run this Microsoft Fix it (or complete these manual steps), standard user accounts may no longer appear on the log on screen when you start your computer or try to switch users. This occurs because standard user accounts are removed from the Users group when you reset Windows security settings. To add the affected users accounts back to the Users group, follow these steps:
1. Click Start, and then All Programs. Or click Programs.
2. Click Accessories, and then click Command Prompt (Windows XP). Or right-click Command Prompt, and then click Run As Administrator (Windows Vista).
3. In the Command Prompt window, type net users and then press ENTER. A list of user accounts is displayed.
4. For each accountname listed in the Command Prompt that is missing from the log on or switch user screen, type the following command and then press ENTER:
net localgroup users accountname /add
5. Now go to the "Did this fix the problem?" section.
Note In Windows Vista, the Defltbase.inf file is a Security configuration template for the default security. You can view the settings for this file in the following location: %windir%\inf\defltbase.inf
For online Help about Secedit, click Start, click Run, type %windir%\help\secedit.chm, and then press ENTER.
Advanced troubleshooting
Method E: Check for any files that cannot be backed up or updated
This method is rated: Moderately difficult.
To complete this method, follow these steps:
1. Determine whether a problem is preventing the files from being backed up or updated. To do this, follow these steps:
a. Click Start, and then click Run.
b. Copy and then paste (or type) the following text in the Open box, and then click OK to open the ie8_main.log file:
%windir%\ie8_main.log
Note By default, the ie8_main.log file is located in the C:\Windows folder.
c. Press CTRL+END to move to the end of the ie8_main.log file.
d. On the Edit menu, click Find.
e. In the Find what box, type ArchiveFileForUninstall:ArchiveSingleFile Canceled.
f. Under Direction, click Up, and then click Find Next.
If you find the "ArchiveFileForUninstall:ArchiveSingleFile Canceled" text, this indicates that there is a problem that is preventing an Internet Explorer 8 file from being saved for removal. For example, text that resembles the following in the log file indicates that a problem exists:
Time_stamp: ArchiveFileForUninstall:ArchiveSingleFile Canceled
Time_stamp: DoInstallation:UpdSpCommitFileQueue for AlwaysQueue Failed: 0x4c7
If you do not find the "ArchiveFileForUninstall:ArchiveSingleFile Canceled" text in the ie8_main.log file, contact Support.
2. Reset the permissions for the Vgx.dll file. To set the permissions of the file to the default settings, click Start, click Run, type cmd, and then click OK. At a command prompt, copy and then paste (or type) one of the following commands, and then press ENTER:
o If you are running Windows XP, copy and then paste (or type) the following command:
echo y| cacls "%CommonProgramFiles%\Microsoft Shared\VGX\vgx.dll" /P BUILTIN\Users:R "BUILTIN\Power Users:C" BUILTIN\Administrators:F "NT AUTHORITY\SYSTEM:F"
o If you are running Windows Server 2003, copy and then paste (or type) the following command: echo y| cacls "%CommonProgramFiles%\Microsoft Shared\VGX\vgx.dll" /P BUILTIN\Users:R "BUILTIN\Power Users:C" BUILTIN\Administrators:F "NT AUTHORITY\SYSTEM:F" "NT AUTHORITY\TERMINAL SERVER USER:C"
3. Try to install Internet Explorer 8. If Internet Explorer cannot be installed, contact Support. If the log file shows a problem, repeat all the steps in this method. If you repeat the process, and Internet Explorer 8 still cannot be installed, but the log file is clean, contact Support
Computers & Internet Logo
Im trying to find my password for my router but i cant.
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router and create a good wireless network security.
Through the Web Administration PagesThe second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router and maintain your wireless network security.
SummaryThis post has provided two methods you can use to reset your Linksys WRT54G Wireless-G router. If you are having problems with your router, try resetting the router to the factory defaults, and then make the changes again and see if the router starts working again.
Sep 24, 2011 | Linksys Wireless-G WRT54G Router
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
I tried to change my password on my wireless router Linksys, and now I can't get on the internet wireless without plugging into the router itself/ could you let me know how I can fix my settings on my computer to recognize my router?? our other laptop can pick up the connection.
  3. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter “admin” as the password.
The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router.
Through the Web Administration Pages The second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page.
Dec 29, 2009 | Linksys Wireless-G WRT54G Router
pin number acces denied
If you have forgotten your password, it is wise to reset the router, Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
  1. Press the reset button for 30 seconds. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  2. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  3. For the login, leave a blank ID and enter “admin” as the password.
Your WRT54G wireless router should now be reset to the factory defaults. Ensure you follow the steps outlined in Securing Linksys WRT54G Wireless-G Router to secure your router.
Hope this helps.
Oct 22, 2009 | Linksys Wireless-G Broadband Router
All the lights or on.On my router.But I cant it on
A couple times a year I have to reset my WRT54G back to the factory defaults. There are a couple of methods to do this.
Reset Button Note:
linksys-reset.png To reset your router, use the following steps:
  2. Open up your Web browser and enter “192.168.1.1? in the address bar.
The router has now been reset. You'll need to go back in and set up any passwords or wireless security you had set up before.
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1?.
The router should now be reset to the factory defaults. Again, you'll need to go back in and set up any passwords or wireless security you had set up before.
Jul 31, 2009 | Linksys Wireless-G WRT54G Router
366 people viewed this tip
David Payne
David Payne
