Tip & How-To about Computers & Internet
Error messages when you try to install Windows XP Service Pack 3
When you try to install Windows XP Service Pack 3 (SP3), you may receive the following error message:
An internal error occurred
After you click OK in the error message, you receive the following error message:
Service Pack 3 installation did not complete
Additionally, you may see the following errors that are logged in the C :\Windows\Svcpack.log file: 165.672: An internal error occurred.
165.672: Service Pack 3 installation did not complete.
165.672: Update.exe extended error code = 0x1ffe054f
165.672: Update.exe return code was masked to 0x643 for MSI custom action compliance
Note Throughout this article, the C :\Windows folder represents the folder where Windows XP is typically installed.
CAUSE
The errors that are mentioned in the "Symptoms" section can occur because of files that are not trusted or because of corrupted registry keys. You can verify the cause by searching for related entries in the Svcpack.log file. Specific entries will identify specific causes of the issue, as noted in the following "Cause" sections.
Cause 1
Determine whether the following entries are logged in the Svcpack.log file: 142.391: CheckVLKForBlock: LIC.dll not trust verified
142.578: Trying CheckVLKForBlock again
142.594: CheckVLKForBlock: LIC.dll not trust verified
142.594: Error: CheckVLKForBlock failed
These entries indicate that the cause of the issue is the Licdll.dll file. The Licdll.dll file may have been altered, is corrupted, or is not trusted. The Licdll.dll file is located in the following folder:
C :\Windows\System32\
Cause 2
Determine whether the following entries are logged in the Svcpack.log file: 211.890: IsSPBetaKey:pLA->lpVtbl->GetProductID Failed: 0x80004005
213.125: Trying CheckVLKForBlock again
214.468: Error: CheckVLKForBlock failed
These entries indicate that incorrect product ID information in the registry is causing the issue.
Cause 3
Determine whether the following entries are logged in the Svcpack.log file: 299.031: Trying CheckVLKForBlock again
299.531: Error: CheckVLKForBlock failed
These entries indicate that corrupted or altered registry keys in preinstalled programs are causing the issue. Note One program that is known to cause this issue is Micrografx - Picture Publisher Professional 10. To work around this issue, see the "Workaround for Cause 3" section.
RESOLUTION
To resolve or to work around these causes, use the resolution or the workaround that corresponds to the cause.
Resolution for Cause 1
To resolve this issue, you must replace the current copy of the Licdll.dll file by using a copy from the original Windows XP media. To do this, follow these steps: 1. Insert the Windows XP CD into the CD drive.
2. Click Exit on the Setup Wizard as soon as it starts.
3. Click Start , and then click Run .
4. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
explorer
5. Click My Computer .
6. Note the drive letter that contains the Windows XP CD.
7. Click Start , and then click Run .
8. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
cmd
9. Type or copy and paste the following text into the Command Prompt window, and then press ENTER:
Expand CD_Drive_Letter :\i386\licdll.dl_ C :\Windows\system32\Licdll.dll
Note In the command in step 9, replace CD_Drive_Letter by using the actual drive letter for the drive that you noted in step 6.
10. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 2
To resolve this issue, you must replace the incorrect product ID registry entry with the correct product ID. To do this, follow the steps in the "Locate and note the product ID" and "Identify and change the product ID registry entry" sections.
1. Click Start , and then click Run .
2. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
sysdm.cpl
3. On the General tab locate the product ID. The product ID is the 20 digit number that is located under the Registered to section.
4. Note the product ID for use in the "Identify and change the product ID registry entry" section. Identify and change the product ID registry entry
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
regedit
3. Locate and then click the registry subkey that resembles the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX
Note The series of Xs represent a placeholder for a string of 21 characters.
4. There may be several subkeys that resemble the format in step 3. To determine the correct subkey, follow these steps: a. Click each subkey in the navigation pane.
b. In the details pane, compare the value of the string for the ProductID registry entry under the Data column to the number that you noted in step 4 in the "Locate and note the product ID" section.
c. The registry subkey whose ProductID registry entry value matches the number that you noted in the "Locate the product ID" section is the registry subkey that you want.
5. In the navigation pane, right-click the registry subkey that you identified in step 4c, and then click Export .
6. Save the registry subkey to the Desktop as temp.reg .
7. Right-click the temp.reg file on the Desktop, and then click Open With .
8. Click Notepad , and then click OK .
9. In the open temp.reg file, locate the following text:
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX ]
10. Replace the text that is mentioned in step 9 by using the following text:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
11. Click File , click Save , and then exit Notepad.
12. Double-click the temp.reg file, click Yes in the dialog box when you are prompted to add the information to the registry, and then click OK .
13. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 3
To resolve this issue, you must delete the InprocServer32 registry subkey. To do this, follow these steps: 1. Click Start , and then click Run .
regedit
HKEY_CLASSES_ROOT\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32
4. Click InprocServer32 . A string value with the name InprocServer32 is displayed in the details pane. Click this value.
5. On the Edit menu, click Delete , and then click Yes .
6. Exit Registry Editor.
7. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
Computers & Internet Logo
install windows xp3
I hope you mean SP3(Service Pack 3) on XP. Please follow these steps
Do one of the following:
  • If you downloaded SP3 from the website, to install it immediately, click Open or Run and follow the instructions on your screen. To install the program later, click Save and download the installation file to your computer. When you're ready to install the service pack, double-click the file.
  • If you're installing SP3 from the Service Pack 3 CD, insert the disc into your computer with your current version of Windows XP running, and the Software Update Installation Wizard should automatically appear. If this wizard doesn't appear, click Start, double-click My Computer, right-click your CD or DVD drive, and then click AutoPlay.
  1. On the Windows XP Service Pack 3 page, click Next.
  2. Follow the instructions that appear on your screen.
  3. After the installation is complete, click Finish to restart your computer.
  4. If you disabled your antivirus software, enable it again.
for more information check the Microsoft website..
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
May 10, 2011 | Computers & Internet
keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Application failed initialise properly (0xc0150002)
I am quoting from Microsoft website for your convenience:
SYMPTOMSWhen you start an Office 2003 program on a Microsoft Windows XP Professional-bas... loadTOCNode(1, 'symptoms'); When you start an Office 2003 program on a Microsoft Windows XP Professional-based computer, you may receive the following error message: The application failed to initialize properly (0xc0150002). Click on OK to terminate the application. CAUSEThis behavior may occur if you install Office 2003 and Windows XP Service Pack 1... loadTOCNode(1, 'cause'); This behavior may occur if you install Office 2003 and Windows XP Service Pack 1a (SP1a) on your computer, and do any of the following:
  • You upgrade your Windows XP Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
In this scenario, when you start an Office 2003 program, you may receive the error message that is described in the "Symptoms" section. RESOLUTIONTo resolve this behavior, after you upgrade your Windows XP Home-based computer... loadTOCNode(1, 'resolution'); To resolve this behavior, after you upgrade your Windows XP Home-based computer to Windows XP Professional, or you perform a reinstall or repair of Windows XP, reinstall Windows XP SP1a on your computer.
After you reinstall the service pack, restart your computer. MORE INFORMATIONFor additional information about how to obtain the latest Windows XP Service Pa... loadTOCNode(1, 'moreinformation'); For additional information about how to obtain the latest Windows XP Service Pack, click the following article number to view the article in the Microsoft Knowledge Base: 322389 (http://support.microsoft.com/kb/322389/EN-US/ ) How to Obtain the Latest Windows XP Service Pack
For additional information about how to install Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/ ) HOW TO: Install Windows XP
For additional information about how to reinstall or repair Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 315341 (http://support.microsoft.com/kb/315341/EN-US/ ) How to Perform an In-Place Upgrade (Reinstallation) of Windows XP"
Aug 17, 2009 | Microsoft Office Professional 2007 Full...
my operating system not uninstalled
What is the system doing when you try to change the operating system?
You should be able to uninstall the SP in ADD/REMOVE Programs.
Nov 24, 2008 | Microsoft Windows XP Professional
ati2dvag caught in a loop
ati2dvag seems to have a problem with XP SP3
I don't know if you have SP3, but if you do, try rolling back to SP2
Method 1: Use the "Add or Remove Programs" item in Control Panel
1. Open the Control Panel
2. Select Add Remove Programs
3. Click to select the Show Updates check box.
4. Click Windows XP Service Pack 3, and then click Remove.
5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder
1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore and select a restore point prior to SP3
Oct 05, 2008 | Toshiba Satellite A105 Notebook
689 people viewed this tip
David Payne
David Payne
