Tip & How-To about Televison & Video
JVC HD-56ZR7J Manual Download
Download JVC HD-56ZR7J Projection TV Manual
Models: JVC HD-70ZR7J / JVC HD-56ZR7J
Have you misplaced your JVC HD-56ZR7J Projection TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC HD-56ZR7J Projection TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC HD-56ZR7J Projection TV manual.
I hope that helps.
_____________________________________________
Televison & Video Logo
Why is my tv jvc hd70zr7j showing a blank black screen when i connect the hdmi signal cable? the ps3 used to work fine before but since i moved into a new place it just shows the black screen
you have a HDMI port Failure that's not uncommon many people fail to turn the units off before switching cables around it only takes a momentary short on the 5 volt line to one of the other lines and it can short it . or it may just be a normal failure . but you would have to change the .with the AV and HDMI ports on it to restore operation . your set probably has more then one port ? have you tried the others . by process of elimination you have ruled out its the game and cables so it points back to the tv
Jan 07, 2015 | JVC HD-70ZR7J OEM TV Lamp
no manual
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jun 15, 2010 | JVC HD-56G787 Television
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
need owner's manual
Click JVC Support to download owner's manual of HD-61FH97 TV
Apr 13, 2009 | JVC HD-61Z575 61" Rear Projection...
869 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
