Tip & How-To about Computers & Internet
Don't Trash That Old PC Just Yet!
Let's face it folks, that expensive shiny new life hub you purchased a few years back is getting old. Yes, the one the salesman told you would last you for years to come. What he didn't tell you is that those years really are only 3-5 before the system is obsolete. Don't fret however! I'll tell you how to get your system back in better than new shape for just an afternoon of your time and for $100 or less!
Now, this tip is for the basic everyday user that keeps that PC around for the internet, email, and the occasional writing of documents. If you are a bleeding edge type of user, you already know what you need to do. Here are my simple steps to get the machine of yours to perform better than when you bought it!
1. BACK UP YOUR FILES!! - Anything important to you should go immediately to disc, flash drives, or external hard drives! Or all 3 to be on the safe side!
2. FIND ALL OF YOUR PROGRAM AND OS DISCS!! - You should always have them in a safe place, and for this task, you will need them!
3. Download KillDisk - A handy tool to erase the hard drive to give you a clean slate to work from.
4. Look at your current memory and video size. You can go to sites such as NewEgg.Com to purchase inexpensive upgrades to your current machine. More ram and a larger video card will allow for new programs and web content to run on your machine much more smoothly than they are now. Use the internet to help you find components that your machine can handle.
OK, now that the prerequisites are taken care of, it's time to get to work!
1. Double check to make sure any and all important files are backed up!
2.. Pop in your copy of KillDisk and boot from it. Follow the simple instructions and step away from the machine for an hour or two while it erases your hard drive. (Single Pass is more than sufficient).
3. Install your copy of your Operating System. This will take around an hour and it's best to check back at your machine every 15 minutes or so to make sure you give it the proper input it needs to continue during various stages of the install.
4. Run drivers disk! You will need these working to access the internet, get your sound going, and all the essentials to make your machine's hardware work as it should.
5. Run updates! It is important to turn automatic updates on and make sure you are at your latest versions of software for both the OS and Hardware.
6. Install your programs and put your backed up files back on your machine. Check for updates for these as well.
6. Install RAM and Video card and prepare to be amazed by how just a couple components can refresh that old machine of yours with a little more speed. While you have the case open, make sure to blow out any dust in the case.
7. Read my previous tip titled: Keep Your New PC In Top Shape...For Free!!! to get the files you need to keep protected and be productive.
That's it folks. It's not too difficult, and chances are you know someone who can help you through this process if you need help. This will give your machine a fresh start, and as long as the hardware keeps ticking, you will be able to hang onto that old PC of yours for a few more years!
Computers & Internet Logo
Samsung SMH1816S suddenly stopped working from fully functional state. A click sound was heard when it went dead. After that no sign of life even with power on. Checked ceramic fuses on noise filter to be fine. Checked the cavity bottom mounted thermal fuses. The left one shows open (has both red color wires) and right side thermal fuse shows connection (has black color wires on its terminals). I am not sure if these are the only ones or I missed anything. Door switches are tested fine too. Can you please help ? Thanks - A
Repairman just diagnosed mine as a bad display board, it quit working while nobody was even home, and cost $269 with a $70 service fee. The microwave is less than 2 years old and only cost @$400 new. I was lied to by the salesman when I made the purchase (imagine that, a salesman lied to a customer) he told me these were very good and reliable microwaves and that I should get years of service out of it, what a crock... I will never buy another Samsung appliance again, they have many many bad reviews and are made with inferior parts. I will stick with Kenmore kitchen products from now on!!!
Apr 04, 2014 | Samsung SMH1816S Microwave Oven
i have zenith director model- z8081 purchased 5 years back, i want to replace the battery, a battery life which lasts atleast for 3-4 hrs
This is an expensive buisness,you can get high endurance replacements (copies) or the genuine thing.
Youll have to consult Manufacturer for estimated life.
And use correct/original adapter not to ruin this lifespan of a new/ replacement battery
Sep 07, 2010 | Computers & Internet
hp pavilion mx 75 monitor displays a flat line across the screen
The life expectancy is about 5 years. You can fix it, but it's not worth trying to track down the power board for a crt, it's going to cost you more than a new monitor. There are flat panels for under a hundred dollars now, you will save that on electricty over a two year period. Although some folks just like them better than lcd's that is no longer an issue, with the faster resolutions in the past few years you will be better off going for a new lcd. HP's website is the most likelly place to obtain service for your monitor, but I just got an email from Dell this morning and you can get a new 19 inch for about a hundred dollars from their reurbished shop if you really want to save some money, and a 24 was only around $200.
Feb 13, 2009 | HP Pavilion MX75 17" CRT Monitor
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
148 people viewed this tip
David Payne
David Payne
