Tip & How-To about Dishwashers
Door sqeaking or falling down? - KitchenAid Kenmore Whirlpool
If the door on your have a stainless steel tank dishwasher is making an annoying squeaking sound or simply drops open unless you support it there is a solution.
The system used to open the door and hold it in place on these models uses rope cables and pulleys. As dust and dirt get on the cables they would make noise usually a creaking or squeaking noise. Sometimes the cables would break causing the door to fall.
The fix for this is a new set of cables and pulleys. They are of a different material that will resist the attraction of dust build up and stay quiet. The link on the end of the ropes have been reinforced to help prevent breaking and the pulleys are of a different bearing design. Over all a very good replacement part.
The part number for this kit is 8194001.(See image below) It comes complete with parts for both sides, be sure to replace both sides even if the noise is only coming from one side. It comes with 2 ropes (24), 2 pulleys (9 &17).
Disconnect the power or unplug the power cord before working on this!
To replace you will need to pull the dishwasher out from the cabinet opening about a foot. Look at the plumbing and electrical to make sure there is enough length to move it out.
Once out you will see the cable (24) that attaches to the spring (18) and to the hinge on the door (not shown), replace the cable and pulley (9).
Do one side at a time, if one side is broken do that side first so you have a a guide to look at if you forget where something goes.
I like to snap a digital picture before I start so I can reference back if I forget what goes where.
Dishwashers Logo
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
door removal
Open the door and remove the 6 screws that holds the metal door panel. The panel will drop down and you should be able to get to the water valve without having to remove the whole door.
Hope this helps.
Nov 03, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
bottom of door makes loud squeaking on opening. I can't figure out how to lubricate. I'm wondering if removing the plastic molding on the bottom inside of the door would allow me access.
Yes by removing the inner door liner from the outer door panel you should be able to gain access to the door hinges,between the part of the hinge on the door and the hinge part on the tub is a plastic bushing that probably worn causing that sqeeking noise.
GENE
Oct 15, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Is there any grease points for the door hinges? The door squeaks every time we open.
Hello. Get a can of a penetrating lubricant called WD-40 with a tiny tube applicator included. Open the door and you will see part of each hinge where the door meets the appliance case. Spray the penetrating lube on the exposed part of the hinge and then open and close the door a few times. Repeat as necessary. J.
Jul 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a stainless steel Kitchenaid dishwasher and the door drops hard when I open it instead of requiring you to push it down if you want to open it fully. Seems like a spring is broken. Any ideas?
there a good chance the springs popped
or the ropes came off the pullys take off the toe kick and peek in on the edges you should see exactly whats going on
Oct 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
1,948 people viewed this tip
Top Dishwashers Experts
