Tip & How-To about Computers & Internet
Make your Ie 7 Fast in windows Vista
1. Click the Start Menu and click the "Run" icon. If a "Run" icon is not listed, press the Windows key on your keyboard and "R" at the same time.
2. Type "regedit" (without quotations) and press "Enter" key to open the Vista Registry Editor.
3. Look for the "HKEY_LOCAL_MACHINE" entry in the left pane and click the expansion arrow next to it.
4.Click the expansion arrow next to the "SOFTWARE" entry.
5.Click the expansion arrow next to "Microsoft."
6.Click the expansion arrow next to "Windows."
7.Click the expansion arrow next to "CurrentVersion."
8.Click the "Internet Settings" entry.
9.Look for "MaxConnectionsPerServer" and "MaxConnectionsPer1_0Server" in the right pane. If you see them, skip steps 10-12. If they are not there, follow steps 10-12.
10.Right-click in the right pane.
11.Highlight the "New" menu item and select "DWORD Value."
12.Create two DWORD values named "MaxConnectionsPerServer" and "MaxConnectionsPer1_0Server".
13.Open the MaxConnectionsPerServer entry by double-clicking it.
14.Enter a number between 10 and 16 in the "value" section in the format: 00000010, where the last two digits represent a number between 10 and 16. 16 opens up the browser to the most bandwidth, making it faster. The default is 6, which is optimal for dial-up browsers
Computers & Internet Logo
how to deactivate shift key sound on windows keyboard
Right click on the speaker icon in the bottom taskbar select playback devices then sounds tab scroll through all device sounds select it then from the drop down list select none
this will vary depending on your operating system
or
Click "Start."
Click "Control Panel."
Click the "Sound" icon.
Click the "Sounds" tab.
Click on the listing for the sound that currently plays when an action is performed on your keyboard.
This will select it. Click the drop down menu on screen and select "None." Click "Apply" to disable the keyboard sound in
hope this helps
Oct 10, 2012 | Computers & Internet
how to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
my samsung N150 does not start up windows explorer
Insert the Windows disk into the computer. Restart the computer. Press any key as prompted to boot from the disk.2 Select your language, keyboard, and currency preferences. Click "Repair your computer."3 Select the drive containing Windows and press "Next" to detect and repair problems with the operating system. OR how to fix Microsoft Internet Explorer when it is not responding to return to surfing the web Click the "Start" menu button in the lower-right corner of your computer screen. Click "Run" and type "msconfig" in the search field. A dialog box will appear that lists all software programs enabled to run when you turn on your computer. Disable all of the programs except for essential services such as your anti-virus software and firewall. Restart your PC.2 Hold down "Ctrl," "Alt" and "Delete" on your keyboard simultaneously. This will activate the Windows Task Manager. Select iexplorer.exe" in the list of running programs and click "End Task." Continue to Step 3 if that does not close the Internet Explorer browser.3 Click the "Start" menu button. Select "Settings," then click "Control Panel."4 Click "Add/Remove Programs." Double-click the Microsoft Internet Explorer icon and select "Internet Tools." Click "Repair Internet Explorer" and press "OK." Microsoft Windows will scan your copy of Internet Explorer for errors or bugs and fix them.5 Open "My Computer," accessible on your PC desktop or in the "Start" menu. Right-click on your "C: Drive" and select "De fragment Occasionally, your hard drive might misplace program data, which results in software freezing or not responding. Repeat the defragment process with the "D: Drive" and any other hard drive partitions.6 Click the "Start" menu button and select "Restart" to reboot your computer and apply the changes made in Step 7 Return to browsing the web with Internet Explorer.
  • Oct 04, 2011 | Samsung N150 Series Netbook
    I have a Dell wireless keyboard with a Calculator-specific function key. It is no longer working after I had some repair work to remove a vicious virus. How can I restore the calculator key?
    Try this. Go to the Start menu by clicking Start (Windows XP) or clicking the Windows icon in the bottom left of your screen (Windows 7). In the start menu, click Control Panel.
    Inside the Control Panel, double click Device Manager.
    Once you are in the Device Manager window, click the Plus symbol next to where it says Universal Serial Bus Devices. In the list of things that comes up, you should see one that says USB Keyboard or Wireless Keyboard, or something to that effect. Right click on that, then click Uninstall.
    A new window will pop up. In that window, click Next 2 times. Then, click Finish.
    Now, unplug the USB wireless receiver. Wait a few seconds, then plug the USB wireless receiver back in. When you plug it back in, it will act like it is the first time it is plugged in, and will reset all your settings. Give it a minute or two.
    Hopefully, you can press the Calculator button and it should work. Hope this helps.
    Thanks for using FixYa.
    Aug 27, 2011 | Dell 0Y3740 Keyboard
    turn on wireless
    To turn the wireless on on your laptop:
    1. Click on Start. Type Mobility in the Search box. Hit the enter key.
    2. In the Search results under Programs you will see Windows Mobility Center. Click on it to open it.
    3. You will see a button under "Turn Wireless On"
    4. Click on it to enable your wireless.
    Another way using a keyboard shortcut: Press the fn and F2 keys at the same time.
    I hope this helps you-Thanks for using Fix Ya.
    May 02, 2011 | HP Pavilion dv4000 Notebook
    806 people viewed this tip
    David Payne
    David Payne
