Tip & How-To about Bose Lifestyle 48 System
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
Bose Lifestyle 48 System Logo
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it has changed. any suggestions welcome.. thank you
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
1,384 people viewed this tip
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
