Tip & How-To about Audio Players & Recorders
Check your emu
Right guys before you panic and start to look for the new keys or codes please check that the emu has not been turned off on your box ok so you have a box t press menu then 1570 this opens a new window or a hidden menu in this you will see nagravision and key emu highlighted scroll down to check that the emu has not been turned off accidently if so scroll over press>to turn on then exit exit if it is a digivox repeat the same procedure only key in 1004 and follow the same steps and again the same with the eurovox only again the difference is 1969 and again the same steps just check before you panic it could be an accident and the emu is turned off
box gone off
Do an AUTOMATIC SCAN. but to make sure you get ALL the channels you need to have KEY EMU turned on. To turn KEY EMU on, press MENU, PARENTAL CONTROL, then on the remote press "INFO" "2004" Go down to KEY EMU and make sure it's on. If you press enter on NAGRAVISION this is where you enter the new keys. So choose TW, Key 0 AA B7 D1 D9 CE 8E 83 AF then press "OK" to save. Now change Key to 01 and enter 8E 80 D7 EF 44 93 02 2B Folllow all that and you should be OK
Jun 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
the box codes please virgin media in bristol may 09
try these codes
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
To enter the codes
1 - Press menu
2 - Press 1570
3 - Make sure key emu is on
4 - Enter nagravision
5 - Make sure it says ntl at the top box, if not press right till it says ntl
6 - Key number should be on 00
7 - Go to key data and put this code in To enter the codes
1 - Press menu
2 - Press 1570
7 - Go to key data and put this code in *******************
8 - Go to key number and press right so its on 01
9 - Press down so you are on key data and enter this code ******************
10 - Press ok to save
11 - All done8 - Go to key number and press right so its on 01
11 - All done
May 22, 2009 | StarTech.com StarView SV211K 2-port KVM...
starveiw box three
Hit MENU Key in 1570 Should open a secret menu Turn the KEY EMU to ON go into nagravision and key in the new codes useing the remote control then hit ok to store
Exit back onto the main screen (press exit x2) Wait for a few seconds for the box to update itself And away you go! hope that helps
Mar 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
box super ntl codes
Dublin, Ireland March09
1 - Press menu
2 - Press 1570
00 Code - B0 B8 4F 04 E6 5F 87 80
01 Code - A3 EB EC 07 D6 49 D2 EB
It you already have these codes and your still losing channels go into set-up and make sure EMU is still on, if not turn on and click ok to store. that should solve the problem.
Jan 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
1,594 people viewed this tip
 Grubhead
Grubhead
