Tip & How-To about Computers & Internet
What to look for when buying a laptop?
There is a lot of people who regret buying the "budget" or the "clearance" laptop. Or probably choosing more space for pictures (Hard drive) then processing power (CPU). This mistakes can cost a lot, because most of the times you can not upgrade. The only way to solve this, is buying another one.
Most people may think of Apple when talking about high-end computers. But there´s a vast array of brands and models running Windows too (at a way cheaper price).
- On a laptop, you want the best or fastest processor you can buy. That way it will not be obsolete in 2 years. DO NOT buy anything at least Core 2 Duo or Athlon II (less expensive). Of course try to aim for the Core i5 or i7 (if you really need speed - these microprocessors are blazing fast!).
- Also you would need more RAM. I recommend at least 4 GB. At least 2GB for regular users.
- If available, get the Windows 7 64-bits (for high end computing. 32 bits systems are limited, they cannot take advantadge of the system resources the way 64 bit does).
- For Hard Drives. More is not necesary the best option. The maximun size I recommend is 500Gb. And I´m saying from the Data Recovery point of view. Please remember, that hig-capacity-hard drives write information verticaly instead of horizontaly, meaning more job for the heads. Think of it as trying to squeeze more information in the same amount of space. Hard drives have not increase physicaly in size, just in the amount of data. In any case, please DO NOT forget to backup, backup, backup!
- If you need your laptop for high end programs, choose a laptop with a dedicated video card. That way you won´t share any cpu or memory resources. (This is not the case for a regular user).
- You will NEED to burn CDs or DVDs. Do not buy the one with the DVD player only. Blu-ray drives can be a little bit expensive
- Find a laptop with the most USB ports possible.
- For screen size. The most logical way of thinking is the BIGGER the BETTER. Well, that is the component adding most weight on a laptop and battery life. Please remember - the size of the laptop does not mean it has the fastest processor.
So, remember CPU and Memory are KEY components when buying a laptop. In case you run out of space for your pictures, you can easily upgrade your hard drive. I hope this tip will help you next time! Please provide positive feedback about this article. Thank you
Leitusdotcom - Leonardo Garcia, CCNA, MCSE:Security
Computers & Internet Logo
How do I choose a Chromebook?
Same as you would choose any other computer. Decide on a budget and then select the features you want. Screen size, speed of processor, hard drive space etc.
Apr 20, 2017 | Computers & Internet
my laptop is in low disk space it was very lag
It would be wise to buy an external Hard Drive and transfer some files to it (especially pictures, video, music that you don't need often).
Mar 03, 2011 | Computers & Internet
How do I choose a hard drive for an upgrade?
You want to make sure you buy a Serial ATA hard drive as for storage space it depends on what you use it for. if you save a lot of pictures and other files you might want to go with a 320 gig or more. other than that if you are just looking to replace the current one and I would order a 160 gig. But make sure it is a Serial ATA when looking. I like seagate and maxtor for hard drives.
Jan 10, 2010 | Samsung Q45 Notebook
Desperate for C:drive space!!
unfortunatly u cant expand a hard drives allocated space past its original limitations. your only options are to buy a new 2.5'' hard drive, a external hard drive or a cheap secure digital card. u can pick sd card up for around £4 a 1gb.
look in second hand electrical retailers for cheap options.
hope that helps.
kev
Oct 02, 2008 | Acer Aspire 3680 Laptop
NEED SPACE!!!
This is a problem only you can solve. Go to CONTROL PANEL / ADD OR REMOVE PROGRAMS. Select the programs you do not want and start uninstalling them. Some of the names may seem a bit obscure and require some research. HP does install a lot of junkware.
DO NOT uninstall updates.
Reboot periodically and defrag the C: drive.
Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=&product=1832426&lang=&
Order the correct Recovery Disk Set for your machine, it should cost less than $16. Do it now while thay are still available.
Now you can strip the D: Recovery Partition and use that space for data files.
You probably have a 4200 RPM hard drive. If the time comes when you need to do a recovery or just want more space, buy a larger, faster replacement drive. 7200 RPM is preferred. Installation is very easy - 6 screws.
Put your existing drive in an external USB case, they only cost about $10.
Your V5000T is an excellent machine and should give many years of productive use.
Jul 08, 2008 | HP Compaq Presario V5000T Notebook
135 people viewed this tip
David Payne
David Payne
