Tip & How-To about Computers & Internet
How to perform enhanced Disk Cleanup on your Windows Operating System
The Windows Operating System tends to collect alot of junk files, programs, and temporary files that you don't need. After a while, these files can fill up your hard drive and slow your computer down.
Anyone can perform the standard Disk Cleanup by right clicking on their hard drive, selecting Properties, and then click the Disk Cleanup button, but who wants to be like everyone else?
To perform a more extensive Disk Cleanup on your Windows Operating System, and to look good in front of your friends, perform the following steps:
Step 1. Click Start and select Run.
Step 2. Type the following in the space provided:
Cleanmgr /sageset:1
Hit the Enter key
Step 3. The Disk Cleanup window will appear. Select all the options, then hit Apply and OK. The window will disappear, but what did you just do?
Well it is relatively simple. The cleanmgr.exe file controls the Disk Cleanup function. The /sageset argument is allowing you to set the options (the selections you made) and the :1 is the value or code you have assigned for the options of Disk Cleanup. But how do we get Disk Cleanup to run using the options we just saved? See Step 4.
Step 4. Click Start and select Run.
Step 5. In the space provided, type:
cleanmgr /sagerun:1
Hit Enter
Step 6. You guessed it. The /sagerun argument is telling cleanmgr.exe to execute value 1.
Step 7. The Disk Cleanup window will appear and begin to automatically perform a cleanup, using the settings you saved, represented by value 1.
Step 8. Do this a few times a week and your computer will stay relatively clean.
Stay tuned for the next Tip as we will setup a scheduled task using this command.
Computers & Internet Logo
Is it worth buying WinCleaner to optimize PC performance
No free products tend to be much better. Malwarebytes is good
Mar 26, 2014 | Logical Business Logic Ultra WinCleaner...
my pc was very slowly running
Your machine is old, there's not much you can do. Remove any programs you don't use, stop programs from starting-up with the OS, and increase your RAM: http://www.crucial.com/index.aspx
Apr 26, 2011 | IBM Netvista Intel Pentium 4 2.4GHz /...
my computer is running slow.
Many factors may cause your Windows 7 running slow: lack of memory, useless programs, wrong startup settings, junk files, registry redundancies, viruses or spyware and more.
If you computer is running slow or starting up slow, you may visit this article to learn more.
Jan 09, 2011 | Computers & Internet
My system work very slow.
Sir you can download an trial software named as system mechanic as it can be downloaded from iolo.com
hopefully it will makes your computer fast as it is now.
Jul 10, 2009 | Microsoft Windows XP Home Edition
no c drive left showing o% space left?
Don't do any mistakes just follow the instructions bellow
  • Delete Junk Files in Windows 10:
  • Search Disk Cleanup in the search box or you can find it under Start > All Apps > Windows Administrative Tools.
  • Click on Disk Cleanup to start the program. You will be asked which drive you want to clean up.
  • The default is C drive. Just make sure it is selected and click on OK.
The disk cleanup program will then start analyzing different folders and types of files that it thinks is safe to delete.
no-c-drive-left-showing-o-space-left-qxiko4mbhn3xwpbyjhiay14v-2-0.png When the analyzing is done, you will be presented with a window similar to the following - it lists what all is removable without causing problems to the operating system or installed applications.
  • Click on Delete Files to permanently delete all the selected items from your Computer.
no-c-drive-left-showing-o-space-left-qxiko4mbhn3xwpbyjhiay14v-2-5.png Which files you can delete safely?
1. Temporary Internet Files
2. Downloaded Program Files
3. Offline Webpages
4. Recycle Bin
5. Temporary files
6. Thumbnails
7. Old Windows folder.
Mar 18, 2009 | E-Machines eMachines Desktop PC
204 people viewed this tip
David Payne
David Payne
