Tip & How-To about Exercise & Fitness
When the walking belt is slipping during use.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Exercise & Fitness Logo
belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
Belt is slipping and catching
Apr 09, 2009 | Exercise & Fitness
slipping mat
Mar 26, 2009 | Exercise & Fitness
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
1,297 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
