Tip & How-To about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
How to wirelessly hook up xbox live GOLD
Wirelessly hooking up xbox live is an easy, simple process; tech savy or not. first, you will need a wireless networking adapter, which range from 80 to 100$ USD. bestbuy or walmart .com are examples of retailers of such product.
hook up the the adpater into the back of the xbox 360.
if you do not have a wireless router that is currently serving no purpose, you will need.
bestbuy and walmart are once again ideal retailers, and i would suggest a Linksys brand router, hook that up and configure to your router.
no more purchases, except for a xbox membership of course.
turn on the xbox with the Wireless networking adapter plugged in and tap the center "Big X" button, scroll right twice and find "network setting" from there, configure network, and then scan for networks...
if you were successful in hooking up the router, you will find your router as an option to connect to, you may or may not have a specified sercurity.
if you do, you will be required to enter the password you chose.
you should now be connected to xbox live...
want a friend? add gamertag: "xInsanitea" and we can play sometime... thanks for reading!
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
how do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
need to hook up xbox live thru wireless internet.
configure wireless router and the wireless of your xbox .
make one sever and the other client .
assign two different address to both ( eg. give the first addrs 199.168.0.1 and other 199.168.0.2)
then connect through wireless .
Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
Can I use a regular windows wireless network adapter with Xbox?
yeah you have to buy some special cables but you can do it wireless and use here a pic
http://www.gocybershopping.com/files%5C/provider%5C%5Cimages%5Ct_2185.jpg
Apr 30, 2010 | Microsoft Xbox 360 Console
what is needed to setup xbox live
Do a google search or go to your favorite electronics website (www.amazon.com is a good one) and search for xbox wireless adapter. You'll be presented with several different ones ranging in prices. If your wireless network uses the "N" standard, be sure to get an adapter that is an N type (in order to utilize the fastest speeds of the wireless system). If your wireless network is not N, then opt for one of the A/B/G adapters (the N adapter will still work, but it costs a little more and you won't get to utilize its faster speeds unless you upgrade the wireless network to N).
Feb 23, 2010 | NetGear WGR614 Wireless Router
my xbox won't connect to my wireless router
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365.
Also you will need to open the ports on the router.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Click Here for more info
Jan 02, 2010 | Microsoft Wireless Network Adapter Xbox...
598 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
