Tip & How-To about Computers & Internet
Linking your system connection to Air
TEMAB COMPUTERS ICT
You moving to the world of internetworking, as in you connecting your system with a dial up or modem so you can access the internet from your home, office and everywhere you may be the following are to be considered .
1. A computer. In order to use dial-up you must make sure not only that you have a computer but that it is going to work with your dial-up service. Some ISP's do not require that you install any software to get connected, so just about any computer would work. However, if they do require that you download their software or run a CD to start their service, you need to make sure that their software is compatible with your service.
For example, your computer may not have a CD drive if it's a compact laptop. Or perhaps you have an older operating systems like Windows 95 or 98. Many installations are not compatible with these older computers. If you have a Mac or Linux computer, you must make sure that the ISP will be compatible with it, or it might not work. If you are using the modem that came with the computer you have to make sure that the modem is installed or updated enough that it will not cause slow connections. Check with a computer technician if you are not sure there is a modem or that it's in good working order.
2. A modem. If your computer does not have a modem, or you wish to use a separate external modem, make sure that it is the correct type of modem. It must be a dial-up modem--broadband modems will not work. Also make sure that your modem is going to be compatible with the services you would like to have on your dial-up. For example, if you would like to add an Internet Call-waiting feature on your dial-up service, you need to have a V.92 standard computer. Otherwise you will not be able to be notified of incoming calls while you are online. Also, if the modem is not in proper working order, for example, it is missing it's latest driver software or has been damaged or corrupted, you will not be able to use it. Thirdly, if the modem is too old and does not have the latest standard, it may not connect as fast as a new one would, so if you know your modem is not V.92, you may need to get a new one so you can get better connection speeds.
3. A land-line telephone. This means your phone line must be an analog phone--cable phones, digital phones, and (usually) cellphones will not work. Dial-up uses analog phone lines because of how it converts and transmits information. It's just like a normal telephone. If you try to use dial-up on any other type of phone, you will get an error connecting because the modem cannot detect the analog dial-tone. Check with your phone provider if you are not sure if it is compatible to dial-up. Also, keep in mind that you will not be able to use your phone and the Internet at the same time, so if you wish to keep your phone line free for telephone calls, you may need to add a second line to your home. However, if you don't want two lines, simply add call waiting and caller ID to you land line and if you have a V.92 modem, you should be notified of incoming calls while you're online.
4. A telephone cord. This may sound silly, but some people do forget about this step. In order to have Internet through dial-up, you must have a phone cord attached from the back of the modem or the back of your computer to the phone jack in the wall. You might want to get a splitter so your phone line can share the phone jack with your computer, or you might be able to connect your computer to your phone or vice versa, using the "line in" and "line out" jacks on the phone or on the back of the computer.
Another important thing to keep in mind is that your telephone cord needs to be as short as possible. Any cord longer than 6 feet could affect your ability to connect to the Internet, or affect how fast you can connect. The longer the cord the more likely you are to have slow or dropped connections. Also, you may need to get a back up phone cord in case the cord you intend to use is damaged. If you buy a new modem, an extra phone cord is usually included.
After all that then you can move to meet an Internet service provider to have their modem or dial up. and their setup for the dial up giving to you. From there have a wonderful browsing and meting people
…………………connecting yourself Globally……………………………………
TEMAB COMPUTERS ICT
Computers & Internet Logo
CANT ABLE TO CONNECT DIAL UP CONNECTION
Turn on your computer. Click the Start menu, go to the Control Panel and access "Network and Internet Connections." Click the "Create a New Connection" option in the upper left corner of the window. Click "Next" until you reach a list of options. Select "Connect to the Internet," and click "Next" again. Select "Set Up My Connection Manually," and click "Next." Select "Connect Using a Dial-up Modem," and click "Next." Enter a name for the new connection you are creating (e.g. "Dial Up Connection"), and click "Next." Type in the phone number you will be using to connect to the Internet, and click "Next." This phone number will be provided to you by your ISP. Enter the username and password provided to you by your ISP. This will successfully configure your Internet connection. Plug a phone line into your computer's dial-up modem. You may now use the newly-created connection to connect to the Internet. b> Macintosh Computers Turn on your computer. Access the Apple menu and click "System Preferences." Click "View," and access the "Network" option. Click on the "Show" pop-up menu and find the "Internal Modem" option-or the "Configure" option if you are not running Mac OS X 10.5-and click it. Click the "Configure" menu if you are running a version other than Mac OS X 10.5. If you are running version 10.5, select the "PPP" tab. These options will both have the same result. Enter your information into the appropriate fields in the new window that appears. Your ISP username goes under the "Account" field, and password under the "Password" field. Save your preferences when you are finished. Plug your phone line into the modem jack on your computer. Your computer will now be able to connect to the Internet via dial-up.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
I have two dell laptops that are having the same problem of no dial tone
First of all, be sure that the connection you have configured on the computers are Dial Up connections.
If you have restrictions activated on the telephone line, removing them might help. Some other services of your telephone provider can also prevent your modems to properly detect the dial tone. It might be worth to take a look in that direction.
It might also be a problem with the telephone line. Try also to dial the number normally entered in the dial-up connections. You should hear a ringing tone shortly followed by noises similar to a fax machine. If you hear this, you access correctly to your providers dial up server and the problem would be with the two computers.
Apr 28, 2011 | Dell Computers & Internet
please make my chat abled
Computer network chatting requires familiarization to capture an experience. First perform computer systems resources checks. For example, chat requires computers that have multimedia features. Microphones provide audio input features while speakers provide out functionalities. Also, computers that require chat requests require internetworked connectivity. For example, dial up telephone internet connected computers least have an extensive capacity with multimedia teleconferencing. Acquire wireless internets also known as broadband connective to capture the impression compatibilities. Prior computer devices function with high speed cable modem connectivity's also preferred to capture teleconferencing. Computer devices acquired at retails as recent innovations are multimedia compatible either with built-in web cameras, microphones, speakers. Resource a requirement that makes the chat conferencing attainable includes installing the software programs designed to provide media displays on computer also over internetworked devices.
Feb 28, 2011 | StumbleUpon Social Network
Connection a Netbook to dial up
if your netbook doesnt have built in dialup modem that mean u cant connect it to a dial up connection. most of netbook in market use wifi as primary connection or sometime comes with built in GSM modem to connect to internet. that meanc the option you can try is to buy a external USB dial up modem
Mar 26, 2009 | Advent 4211c Notebook
missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
135 people viewed this tip
David Payne
David Payne
