Tip & How-To about Computers & Internet
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
Computers & Internet Logo
hello, i have 2 questions: 1- i need to know if there is away to convert "Arabic protected PDF book into DOC " 2- i need to know is there is away to supervise my team while the are dealing with costumer online , we use Skype but when we audit using Skype , conversation between our representative and our customer is going slow as it's video chatting , so what is the perfect program to know what's happening in the on line class for supervision on my team - i need to hear the full class to appraise it
PDF is the only document format that typically allows you to view the file, instead of editing with many means like data encryption techniques, passwords and local restrictions. Due to these actors, users prefer to convert PDF to Doc format so that they can access and make changes to the data. Once converted to Word format, files become open for modification, editing, printing, copying and extracting information. Using Doremisoft PDF to DOC converter is the most effective method to convert PDF to Doc with utmost ease and accuracy.This is an easy-to-use and efficient PDF to Word utility that converts PDF to Word DOC file with great precision. Good Preservation PDF Converter preserves all the elements of original PDF files, such as text, hyperlinks, images, layouts, tables, columns, and graphics. The best aspect about this utility is that as a user you can also convert password-protected PDF file. During the process of PDF to word conversion, the software prompts the user to enter the password. As a result, it is very important that the password of the PDF file must be known for PDF to Word conversion.Key Features of PDF to docx converter:
1.Support all Windows platforms, Windows Server 2008, Windows 7, Windows Vista, Windows XP, Windows 2003 and Windows 2000 2.Provides complete support to the conversion from encrypted PDF files and password protected documents 3.Preserves the Text, Pictures, and Layout even after the successful conversion of file from PDF to Word DOC format 4.Supports Unicode Character Conversion 5.Perform the PDF to DOC conversion at a very high speed 6.Allows user to convert entire document or only a specific page range 7.Converted files can be automatically opened immediately after conversion complete 8.Provides round the clock technical support 9. Preserve data structure, formatting and properties of content 10. This PDF to Word Converter is compatible with Microsoft Office 2010, 2007, and 2003.Pricing and Availability:Doremisoft PDF to Word converter is priced at $39.95 for single user license. You can downloaded online from Doremisoft pdf to word converter website
Sep 22, 2011 | Microsoft Office Professional 2007 Full...
Hello! I have lost my PDF file password, I wonder how I can get it back
PDF Password Remover is an amazing and professional software to remove the use/open password and restrictions (owner password) on printing, editing and copying from your PDF files.
Feb 02, 2010 | Adobe Computers & Internet
310 people viewed this tip
David Payne
David Payne
