Tip & How-To about Washing Machines
Oasis washer dreaded F-51 error
F-51 is rotor position sensor (RPS) failure due to over loading , imbalance or something caugt between tubs.etc. I have the link to the kenmore Oasis service manual Here in my stash along with a ton of other manuals on my youtube channel on YouTube in the about section link is below:
Dan Webster
Washing Machines Logo
f-51 code
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Codes
Motor RPS Failure (rotor position sensor)
F then 51 flashes when there is a motor rotor position sensor failure.
The overheating of the motor sensor is caused by use of excessive detergent. This washer can detect suds and try to correct. Upon doing so it causes the motor to work more and overheat which causes the RPS to fail.
See page 7
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
f-51 error code. washer will not run.
F-51 points to a "motor rotor position sensor (RPS) failure or lower harness problem.
if you are handy with troubleshooting using a multimeter, there are steps here (www.servicematters.com) under technical reference to help you. just enter 27082 as the model number.
Top Washing Machines Experts
john h
