Tip & How-To about Computers & Internet
NET Speed fast distibute the network
If there are many pc connected in roter .and ur computer LAN IP ip is automatic u give DNS ip and ur net and browsing is working good.
Computers & Internet Logo
i have an aptiva desktop and i need an ip address in order for my internet to work
But do you have any internet connection??if yes and if its DSL than ur dsl router will automatically provide ip to ur pc???
Sep 08, 2010 | IBM Aptiva E 572 (2174572) PC Desktop
trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet connection is cable. Please help. thank you
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
i was using bsnl provided nokia modem. i had to reload windows xp since my pc was not working.but now i am not able to connect to net. ''error 169. desitnation not reacheable''. plez solve this
r u using lan connection or usb..need to know..??
assuming that u r using lan connection, u know the primary n secondary dns provided by bsnl (if so), & hv knowledge abt PPPoE connection..if not u gotta clarify more....!!
however, see if ur lan settings are ok n there is no conflict..open Control Panel->Network Connection->right click on Local Area Connection->click Properties->choose Internet Protocol TCP/IP from item menu->click on the Properties submit button therein->manually configure it by clicking on the radio button as 'Use the following IP address'->IP Address:192.168.1.2; Subnet Mask:255.255.255.0; Default Gateway: 192.168.1.1->put the DNS if u hv->nw press OK->OK..
make a through system scan with ur licensed, 'updated' antivirus (i prefer AVG/Kaspersy) and Microsoft Malicious Software removal Tool..
..always better to hv ur System Admin/Vendors supervision....
Oct 27, 2009 | Computers & Internet
Can't access the web
Check LAN IP configuration properly, also check Gateway and DNS configuration.
Try to Ping your local host.
Start>Run>Cmd enter ipconfig/all and check your ip configuration.
Also check your server ip configuration.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread with the results of your work.
Regards;
Hassan
Jul 22, 2009 | Dell Latitude D610 Notebook
899 people viewed this tip
David Payne
David Payne
