Tip & How-To about Computers & Internet
Computer froze when shutting down? NTLDR MISSING? READ IF THIS HAS NEVER HAPPENED INCASE!!!!!
This is more of a disappointment for most people than a tip.
As rare as it is some people's computer freezes while shutting down and when they pull the plug, it doesn't boot up again.  This is a very serious case because it isn't easily fixable.  In fact I still haven't found a way on fixing it without a windows disk but basically what has happened is while windows was busy with files in the process of shutting down, it lost those files and cannot retrieve them.
Here are some links that I found that are helpful.
●http://support.microsoft.com/kb/318728
●www.tinyempire.com/notes/ntldrismissing.htm
●http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/
●www.tech-pro.net/howto-fix-ntldr-is-missing.html
Computers & Internet Logo
dell problem freezing
Not much to work with. Try shutting down unnecessary processes. It would be Helpful if we knew more, What were you doing when it froze? Perhaps it just needs some Cleaning and tuning up? Tow many running processes? Here are some Windows XP speed up tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer
May 11, 2013 | Dell l Latitude 620 9300 9400 1...
asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
r31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
can not get cashout on one computer
Does the computer run fine besides doing CC tips or punchout. Does it create tabs and do cash sales ok?
Jul 05, 2008 | Pc America Restaurant Pro Express
135 people viewed this tip
David Payne
David Payne
