Tip & How-To about Computers & Internet
How to make a batch file
How to make a batch file.
A batch file is basically a file containing all the information that would be typed into a cmd window without having to type it everytime you want to use it. This is useful when you want to do things like syncronising folders between your flashdrive and your computer.
1.) Go into the start menu and go to "Run".
2.) Type in "notepad.exe" and click ok.
3.) Type in all the command lines that you want in the text document.
4.) Go 'File', 'Save As'.
5.) Save as file type... All Files. Type in the name and type in what you want and next to it, ".bat"
Then run the file you saved and it should run in the command line window.
Was this useful/good...?
Computers & Internet Logo
How to Create a Batch File?
Use "notepad" to type in the commands you want in the batch. Save the file with the extension, "cmd" as in, "batch.cmd". You have a batch file now. It's just commands in a file.
Oct 18, 2016 | Computers & Internet
My viewsonic laptop its asking to type a x.source but its saying its a batch file what is that coman prompt
x: source the is drive letter which has the batch file. If your batch file is in a usb drive check the drive letter ( E:, F:, etc).
Press Windows Key + R, and type cmd in the box appeared and press enter, you will get command prompt.
Dec 10, 2014 | Computers & Internet
how to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
smple script for graceful shutdown of Windows OS
a simple batch file could be used
down.bat
@echo off
IF "%1"=="" GOTO DEFAULT
IF "%1"=="a" Shutdown -a
GOTO END
Shutdown -r -t %1
GOTO END
:DEFAULT
Shutdown -r -t 30
:END
This batch file accepts the inputs as follows
"down.bat" This will shutdown in 30 secs and is default
"down.bat 120" This shuts down in 2 mins
"down.bat a" This aborts any shutdown operation.
Hope this is what your after
May 07, 2009 | HP 3000 XR (j4367a) UPS System
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
125 people viewed this tip
David Payne
David Payne
