Tip & How-To about Computers & Internet
Preventing Reinfection of Virus for newly installed XP.
Hello XP users, Hi, here is a tip of how to prevent viruses from reinfecting your PC, the virus is well usually comes from your USB flash drives, and or your back up files from your hard drives as I assume you have a Drive D: Here are the things you should do so that you will not get reinfected.
Im assuming you are using XP
1. Reformat/reinstall again your OS and as for your Hard Drive, set 2 partitions, for system this would be drive C: and for Data, this is for drive D:2. After installing the XP (you now at this point have a start button) caution: do not use any flash drive or open your other drives, set you folder options to Show all files and Folders.
start->my computer->tools->folder options->view on the hidden files and folder, select Show hidden files and folderand uncheck the two checkbox below, (this is hide extension and hide protected .... )apply and or OK
3. Run GPEDIT.MSC from the RUN option
start->run then type GPEDIT.MSC then OK
4. Under Group Policies, goto administrative templates -> system -> turn off autoplay then enable select all drives -> OK ->exit
this will make the autorun.inf functions not to load automatically. This option makes the virus not to load automatically. caution again, at this point be cautious of what you will DOUBLE CLICK.
5. install an antivirus software, (any freeware will do, but i prefer the AVAST one)
your PC is now protected from reinfections.
you can now scan ALLl your drives and flash drives.
You can also manually delete the virus files on your drives. they are usually folder looking files, usually 743/744 bytes. You can also see some recycle bin ICONS with unusual names (who created them?) If you did not create them, erase them files.
Run SEARCH on all drives except C: with all .EXE files and under the what size is it? select medium. then click search.
on the search result, delete all the folder looking .EXE files with 743 or 744 bytes (usually).
caution one more: before opening a removeable flash drive, do the SEARCH thing on this drive.
Your done. = }
Computers & Internet Logo
My Kingston usb flash drive (4Gb) is not recognized by my computer.
Hello Sir, Hi, try scanning your PC with anti virus software, and an anti-malware scanner as well. you can download one from download.cnet.com, the PC that you are using may be infected. If the scan does not detect a virus or if you are sure that your USB Flash drive is clean, check you BIOS setup and enable the USB function.
Jan 14, 2011 | Computers & Internet
i have format my pc 4 times but virus cant remove from my pc ask solution
Smash your hard drive with a hammer.
Then go get a new one.ITs ruined.
Apr 28, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
After turning on laptop the black screen that says Windows XP appears as usual. But then, the regular blue screen comes up with Windows XP and it stops right there. It doesn't move on to the screen where I can pick which user! The "thinking" light is flashing, but the screen is not changing; like its stuck or something.
ok try to reboot then while its booting press f8 key then when the screen come up go into safe mode! try running your virus software i hope its up to date!!also run a hard drive check for bad sectors! WHEN YOU HAVE ALOT OF USER ON ONE COMPUTER YOU WILL HAVE PROBLEMS BECAUSE IF ONE USER HAVE A VIRUS THEN IT WILL STALL YOUR COMPUTER!SOMETIME YOUR VIRUS SOFTWARE
WONT SCAN EACH USER ONLY THE ADMIN!!
Nov 01, 2009 | Dell Inspiron 6000 Notebook
104 people viewed this tip
David Payne
David Payne
