Tip & How-To about Kitchen Appliances - Others
How to use a Presto Tater Twister
To use a Presto Tater Twister, first take your choice of cutting disks and snap it into the the bottom of the white cylinder. Next, push the potato onto the rotating cross-shaped platform in the bottom of the clear container, and place the clear container onto the motor. Last, turn on the motor, and gently push the white cylinder containing the blade down into the clear cylinder. Your curly-cut potato will emerge into the white container, ready for your deep fryer!
Kitchen Appliances - Others Logo
How do you make sweet potato dumplings?
Spray a 13x9x2 inch baking dish or pan. Take one can of biscuits and peel each one in half, (you'll have 16 pieces). I have used crescent roll dough, but biscuits are easier. Press biscuit pieces to flatten them and place sweet potato to one side of the biscuit. I use frozen sweet potato patties but, you can use canned sweet potatoes (mash them good) for this recipe. Cut the patties in half or use 1 heaping tablespoon of mashed sweet potato and put the sweet potato to one side of the biscuit. Sprinkle with your spices of choice ( pumpkin pie spice,apple pie spice or even just cinnamon). Bring the one side of the biscuit over the other side and press the edges together to seal it really good. Line your dumplings in two rows in your baking dish, sprinkle with your spices of choice. Now, in a saucepan combine 2 cups of water,2 cups of sugar,1 1/2 sticks of butter (or margarine), 1 tablespoon of corn starch, 1 teaspoon of vanilla. Whisk together and put on a medium-high heat until just boiling-- all the time whisking ( to prevent lumps). Soon as it boils pour it over the dumplings. Bake at 350 degrees for 45 minutes. When you pull it form the oven sprinkle with cinnamon and serve. If there is any left-over (HAHA!) It reheats well and is still SO_O_O_O fantastic!
Jul 11, 2014 | Cooking
WANT T REMOVE BASE OF BROKEN BULB STILL IN SOCKET RANGE
Unplug the oven. Take a potato and cut it in half. Jam it into the socket as far as you can. Now unscrew the broken socket by turning it counter-clockwise. The potato will form to the inside of the socket and twist it out.
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
PRESTO Tater Twister Instuctions
  • 1
    Take the inner piece of the Tater Twister, the large white circular piece, and place upside down on the table. The two handles should be on the bottom and not the top.
  • 2
    Choose your cutting disc and insert it into the inner piece of the Tater Twister. Insert the disc with the bladed side facing downward. There are two tabs on the side that should snap into place on the inner piece of the Tater Twister.
    • Free Daily News on your Cell Phone. All news on potatoes & products
  • Plug in the main Tater Twister unit, the glass blender-like piece. Insert a potato or other vegetable into the Tater Twister. There are several small studs sticking up in the bottom. Push the vegetable down onto those studs to hold it in place.
  • 4
    Push the switch on the front of the Tater Twister to turn it on. Take the inner piece and turn it right side up so you can hold the two handles.
  • 5
    Lower the inner piece into the Tater Twister. Position it so the handles line up with the two large slits in the Tater Twister. As you push down, pieces of the vegetable are pushed through the cutting blade.
  • 6
    Continue pushing until the inner piece has reached the bottom. Turn off the Tater Twister by pushing the switch on the front into the off position. Take out the inner piece and dump out the cut vegetable pieces onto a plate.
  • Parts For Porsche Panamera
    Jun 15, 2012 | Cell Phones
    Don't know how to assemble and operate my presto tater twister
    Hi
    The clear piece twists on to the housing that has the motor If you look at the other piece that is white you will see tabs The cutters clip to the bottom with the point facing out Place the potato on the disk in the clear part Then place the white piece with the cutter into the clear one press into the potato Then turn it on and press down on the handles till the potato is cut :)
    Nov 23, 2011 | Kitchen Appliances - Others
    I want to know how to bake a potato in a galaxy microwave oven?
    Poke some holes in the tater with a fork... then microwave the tater for thre to five minutes until soft through, depending on the size of the tater..
    heatman101
    Jun 07, 2011 | Microwave Ovens
    487 people viewed this tip
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Irene Tulloch
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
