Tip & How-To about Computers & Internet
Pc secreat
In windows xp go to run and type msconfig then new box appears click start up and disable all and okkk it will increase ur system speed
Computers & Internet Logo
schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
My core speed drop always to 999,99 then 2000 then 1999 then 2500 and 2700mhz whats the problem ?? plzz help ??
some tips to increase your system performance
If you have an old and slow computer, do following to increase your system speed:
1- Disable Scan Disk
Click Start menu > Click run. In the run dialog box type: msconfig to open System Configuration Window. Then open "system configuration programs". In the General Tap click on Register and then check "Scandisk after error by shutdown disabled" to disable ScanDisk.
2- Disable auto start programs
Open System Configuration (msconfig) . click on the "Startup" tap and in the application list , Clear the check box for a startup item to disable it on your next boot.
3- Disable Windows Startup sound
Go to Start > Settings > Control Panel and then click on " Sounds and Multimedia" icon to open it. In the Sound tab disable Windows Startup sound.
4-disabe unused programs
Go to Start > Settings > Control Panel and click on "Add/Remove Programs" and uninstall old and useless programs.
5- Delete offline e-mails
Yes, offline e-mails especially e-mails with attachments can slow down your pc. Delete these e-mails.
6- delete temporary internet files
Temporary internet files can slow down your pc. In internet explorer click on tools menu and then select Internet Options and the click on " Delete Files and Delete Cookies" buttons to delete these files.
7- Defragment your Hard Drive
Defragment your hard drive every 10 days. To defragment your Hard Drive, click on Start menu > Programs > Accessories > System tools > Disk Defragmenter.
8- update your Windows
Turn on your Windows Automatic Update to have recent updates for your Windows.
do it in your system.Thankyou
Sep 04, 2009 | AMD Athlon 64 LE-1640 Processor...
application rtl100.bpl
Hello!!
Insert ur XP cd and boot it thro the cd and enter the repair console and try FIXBOOT command .. or try the other method .. run msconfig .. and disable the error in startup menu .. thanks for using fixya!!
Feb 23, 2009 | Dell Microsoft Windows XP Home Edition
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
120 people viewed this tip
David Payne
David Payne
