Tip & How-To about Televison & Video
One way to tell if your remote control needs to be replaced
Look at the output end of your remote control. Press a button on the remote control. Notice you don't see anything. Turn on a digital camera/cell phone camera and look at the output end of the remote control through the viewscreen. Now press a button. If you see a flashing light the remote control is most likely working. If you do not see a flashing light when you press a button on your remote control while looking at the output end through the viewscreen of a digital/camera cell phone camera then your remote control most likely needs to be replaced.
Televison & Video Logo
Receiver does not respond to the remote control (AVR 65S). Seems either product is defective. How to tell which one is defective?
The obvious answer is to change the batteries in the remote control! If this doesn't work, you can check if your remote control is outputting anything by pointing it at a digital camera, and while viewing the camera's screen, press one of the buttons on the remote. You should see a white light appear on the camera's screen if the remote is working. This doesn't work with ALL camera's but it does with 4 of my video and still digital cameras. This should at least let you know that the remote is functional, it doesn't mean that it is programmed correctly.
Mar 29, 2015 | Harman Kardon AVR 65 Receiver
it don't work even the battery is new
If the remote is not working,try to open the remote and check the battery terminal the one that is connected in the pcb if loosed, then if you have a cellphone with a camera, point the sensor in the camera lens then press any button, then try to look the monitor of your cellphone you will notice that their is a glowing red light it indicates that the sensor is in good condition if you do not see anything try to replace the sensor.
Jun 24, 2011 | Televison & Video
Remote does not work for samsung ht-c550 Lights work when the button is pressed but the device is not receiving the signal.
The batteries may be to low to operate the IR transmitter, but still turn the lights on when you press a button.
If you have a cell phone with a camera, turn the camera on and look IR transmitter end of the remote. It may have a dark red lens. Press some buttons on the remote, and you should be able to see the IR signal in the cell phone. If not, try new batteries in the remote. If that does not work, it could have a problem with the code for the TV. Try to reprogram the TV button.
Nov 11, 2010 | Samsung TV Remote Control
238 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
