Tip & How-To about Audio Players & Recorders
Entering codes to your box t /digivox/eurovox
Right guys in the hope that you had everything right and unfortunatly your box gets scrambled and you need to input the newest codes manually step 1 on your remote press menuafter you do this you then press the appropriate no or code for the box you have ie.box t 1570 step 2 after you input the code and it opens the new menu/hidden menu remember you cannot access the hidden menu /or emu unless you had the firmware installed before they scrambled step 3 there will at this stage be only one or two lines in the list high lighted usually nagravision and key emu press nagravision that will scroll to another page step 4 it will then say service provider which means who ever your signal is been received from???step 5 you will then see no like 5a01written beside the service provider you must input the proper one for your provider if it is not allready there usuall when you find your provider this no. is there step 6 under this you will see two lines of no.and letters step 7 scroll down to the first line which is usually line 00 then if you have got the new line or codes you simply follow the no keys on your remote to input the no and the coloured keys to input the letters after you have the top line done you must save them by pressing on the ok button on your remote step 8 you then repeat this for the second line marked 01 input the new code again on this line press ok and on the very bottom of the screen you will see the save flash while you press the ok button step 9 you then simply press exit exit back to main screen and all should be working if not you just repeat the steps and make sure you saved the codes line 1 after you put in line 1 and line 2 after line 2 hope this makes things easier on you and helps
I'm connected to a dish network receiver and the picture was good until my son tried to plug in his playstation 2. Now everything is back to the way it was originally installed except there is a scrambled picture, good sound and you can change the channels, but the picture remains scrambled in a random patttern. I question if it is a receiver problem or a Television problem. Any suggestions?
Hey there. You want to make sure that the cables are tight on the back of the receiver and also that the tv is on the correct channel or input. Sometimes, if the tv is on the wrong input, you can get the picture, but it will look scrambled. So if you are in the room with the receiver box, you want to make sure that the tv is on channel 3 or 4, and sometimes on an input like Video 1 or 2. If on the secondary tv, you will want to make sure that the tv is on channel 60 or 73. I hope that this helps. You can follow this link below if you need more clarification.
http://www.dishnetwork.com/SupportSection/bbs-screen
Becki Barned
DISH Network Customer Service
Nov 16, 2010 | Insignia IS-LCDTV32 32 in. Television
i need help with x box live some guy took my acount
Try to recover it but if that doesn't work, there's sadly nothing you can do to get it back. And unfortunatly you lost your gamer score and history of games and everything. Will have to start over from scratch. Hope you can recover it!
May 27, 2010 | Microsoft Xbox 360 Console
starview channels missing
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
Feb 20, 2010 | StarTech.com StarView SV431USB 4-port KVM...
the box super
hi i have the super box has anyone got the new code
Aug 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
1,499 people viewed this tip
 Grubhead
Grubhead
