Tip & How-To about Computers & Internet
Make Firefox quickly
If you feel your firefox browser was slow or often susceptible to interference and does not satisfy you can try these tips and you should do it at the time no luck online.good luck
Computers & Internet Logo
Fix Ya Com
It seems problem is due to the slow internet & browser I would suggest you to apply these tips:-
- Remove extensions of browser.
- Clear history & cache.
- Check your preferred DNS address.
- Fix browser registry & internet settings with reliable program (must use RegInOut to fix it properly.)
- Update The Adobe Flash Player & Java.
Enjoy :-)
Nov 25, 2013 | Mozilla Firefox
Keep getting out of sync warnings on fb game Farmville& cityville
Good Day Dilles!
It is an internet connection issues. The page is loading too slow. It is better to disable your Firewall settings.
I do recommend you download and install the latest Adobe Flash Player. If you want to be more satisfy playing Facebook games, I do recommend you use Mozilla Firefox when you access your Facebook account.
To download:
Adobe Flash Player, go to http://get.adobe.com/flashplayer/
Mozilla Firefox, go to http://www.mozilla.com/en-US/firefox/new/
Jun 08, 2011 | Computers & Internet
firefox slow, why
"Fast" or "slow" is a subjective and unscientific description. If Firefox is not running at the speed it usually does, you should try disabling any add-ons you have recently installed and see if the problem corrects itself. If Firefox does not perform in the way you expect it to on a given computer, the computer may be equipped with a slower processor or less RAM than you are used to.
Sep 06, 2010 | Canonical Ltd. Ubuntu
Firefox is slow to open and getting a lot of error messages saying websites are not a valid url.
Here are some steps follow it to resolve your issue:
1. Uninstall the latest buggy Skype plug-in: If you are experiencing that Facebook, GMail or Google Reader are really crawling and you’ve recently updated Skype to version 4.1 and installed the Skype plug-in for Firefox, try uninstalling the Skype plug-in, but leave the main Skype program installed. That should help. Hopefully, Skype will update this plug-in soon because, reading the tweets on slow firefox, it’s certainly responsible for driving a number of people away to other browsers, particularly Chrome.
2. Check how much memory Firefox is using: Bring up Windows Task Manager with Ctrl-Alt-Del in Windows XP or Crtl-Alt-Esc in Vista and go to the Processes tab. Look for the process called firefox.exe and check the memory usage: for example, 230,000K is 230MB. Try cutting back on the number of tabs you have open and uninstall any plug-ins you really don’t need and see if this brings down memory usage. If you’re anything like me, you’ll have installed plug-ins which seemed a good idea at the time but which you now rarely, if ever use. Uninstall them.
3. Do some maintenance: Use a program like CCleaner (for Windows) or BleachBit (for Windows or Linux) to clear your browser temporary files, internet cache and browser history regularly.
4. Modify the Firefox config file: Here’s some tweaks which involve modifying the config file for Firefox. I’d heard some of these a while ago on the Mike Tech Show podcast, also at Life Rocks 2.0. It’s not difficult to edit the config file. Just type about:config in the Firefox address bar and press enter. Then type network.http in the filter field. This will filter the list down to only those with network.http in the name. Now make the following changes:
  • Double click on ‘network.http.pipelining’ and set the value to true (double clicking toggles the value between true and false).
  • Double click on network.http.pipelining.maxrequests’ and in the dialog box enter a value higher than the default value 4. According to Mozillazine, the maximum you can use is 8.
  • Double click on ‘network.http.proxy.pipelining’ and set the value to true.
  • Again in the filter field enter ‘browser.sessionstore.interval‘ (without the quotes), double click on the entry and change the value from 10000 (10 secs) to 120000 (2 minutes). This adjusts how frequently Firefox creates session restore save points. Firefox will now take a snapshot of your browsing session every 2 minutes instead of every 10 seconds.
  • Right click on the page and select New->Integer. Enter the name nglayout.initialpaint.delay and then click ok. Set the integer value of this to 0 and click ok.
You can find additional great config file tweaks at Technically Personal.
5. Disable Firebug: If you’re using Firebug, it can slow Firefox to a crawl.
6. Optimize Firefox’s SQL database: Firefox uses SQLite databases to store lots of its settings. With time, the databases grow and Firefox slows down. Use either Vacuum Places Improved, a Firefox add-on, or SpeedyFox, a stand-alone app to compact these databases without losing any data. I prefer SpeedyFox as I like to keep the number of Firefox add-ons to a minimum. Only works in Windows at the moment though. Thanks again to Life Rocks 2.0 for this tip. I also use the portable version which doesn’t modify the Windows registry.
7. If you’re still not happy with Firefox, there’s a terrific Firefox Troubleshooting Guide over on MakeUseOf.com. And have a look at this post at Dedoimedo for more suggestions.
8. And if you’re still not happy, try Google Chrome – it’s a worthy alternative to Firefox.
Oct 15, 2009 | Mozilla Firefox
HP Pavilion dv5000
Try downloading Mozilla Firefox, a different browser and less susceptible to viruses than Internet Explorer. You can do this at www.mozilla.com/firefox.
Dec 17, 2007 | HP Pavilion dv5020us Notebook
220 people viewed this tip
David Payne
David Payne
