Tip & How-To about HP Compaq Presario V2000 Notebook
How do I backup my files and folders in XP?
Windows XP comes with a backup tool called NTBACKUP (NTBACKUP.MSI from Windows XP CD-ROM). In Windows XP Home Edition, this tool has to be installed manually from the CD-ROM, whereas in Windows XP Professional, this tool is installed by default.
Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD to start a wizard that installs NTBackup: X:\VALUEADD\MSFT\NTBACKUP
X:\ refers to the CD-ROM drive-letter
Note: Usually, OEMs such as Compaq, DELL won't ship the Windows XP CD nor they include the NTBACKUP utility by default. You can download a copy of NTBACKUP.MSI here
Backing up your files using NTBackup Utility:
Click Start, Run and type NTBACKUP
Select Backup tab at the top
In the left pane, scroll to the file/folder which you want to backup and put a checkmark on it.
At the bottom, mention the output filename (the backup output)
Once set, click Start Backup button in the right, and again click Start Backup in resulting dialog
NTBACKUP does not have the ability to write to CDs directly. You will need to save the backup to hard drive, then transfer or burn it to a CD-ROM. Also, while backing up several files, make sure you backup the files in separate sets of each max 650MB (so that it fits on a CD-ROM)
See also FREE Windows Backup Software add-on for NTBackup
Enhanced Windows Backup uses Windows' built in backup engine called Windows Backup (ntbackup.exe) which provides state-of-the-art core backup technology. Enhanced Windows Backup substantially extends the capabilities of NTBackup, providing an effective integrated backup solution.
HP Compaq Presario V2000 Notebook Logo
my computer formatted i have genuine product key how to get win xp home edition and install in my computer
Put the genuine Microsoft CD-ROM disk into your CD-ROM drive.
Restart your computer.
As soon as it starts, look for a message like "press Fxx to temporary change boot-order".
Press that key.
Select to boot from you CD-ROM drive.
This will start to install Windows, by reading from the CD-ROM drive.
Apr 23, 2011 | Microsoft Windows XP Home Edition
I bought my computer from you in June 2008, service tag 73SCFG1. Recently I tried, for the first time to use the backup feature to store data. I noticed that the software did not have that capability, although the operating system should have it. How can I downlaod that feature?
Is your Operating System Windows XP Home by any chance? That did not come with backup software installed. However, there is a way...
To Manually Install the Backup Utility
  • Insert the CD Rom and navigate to CD-ROM Drive:\VALUEADD\MSFT\NTBACKUP
  • Double-click the Ntbackup.msi file to start the wizard that installs Backup
  • When the wizard is complete, click Finish.
Nov 28, 2009 | Dell Computers & Internet
I can't find back/up wizard in system/tools on Dell-C521
You probably have XP home edition
Although Windows XP Professional Edition and XP Home both ship with NTBackup, only XP Pro installs NTBackup by default. You can install NTBackup for XP Home by performing the following steps:
  1. Insert the XP Home CD-ROM.
  2. Navigate to the VALUEADD\MSFT\NTBACKUP folder.
  3. Double-click the ntbackup.msi file to install NTBackup.
I found these instructions here
Credit where credit is due :)
Jul 11, 2009 | Dell Dimension E521 PC Desktop
Windows Backup
The backup program only came installed in the Pro version. In the Home version you need to install it from the original operating system CD. Put the CD in the drive. Goto Start, Run and type (CD Drive):\valueadd\msft\ntbackup. This will install the backup program.
Apr 06, 2009 | Computers & Internet
When I click on the Windows Backup icon to start the backup program nothing happens
You may need to re install it............
Using your Windows CD :
To manually install Backup: 1. Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD-ROM to start a wizard that installs Backup: CD-ROM Drive:\VALUEADD\MSFT\NTBACKUP 2. When the wizard is complete, click Finish.
Jul 14, 2008 | Computers & Internet
2,346 people viewed this tip
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
