Tip & How-To about Audio Players & Recorders
How to change your mp3 background
Go to the menu and you should be able to change it there
ip address change
Press "Menu"
Scroll to "IO sub menu" Enter
Scroll to "TCP/IP" Enter
Scroll to "Manual settings" Enter
You can see the saved IP address, it can be change, enter desire IP address...enter for save the changes....back to main menu..
To confirm: (You can follow the above said method to see the saved IP) OR
Press "Menu"
Scroll to "Information menu" Enter
Scroll to "Print menu map" Enter
Printer prints menu map, you cam see the entered IP address here, if you found its success, if not try once again..
May 12, 2014 | HP Laserjet P4515x Printer
NEC TV - How to change language of menu
I just bought an NEC FS-5160 from a local opportunity store last Friday (July 2, 2010) with the same problem. After a few minutes of fiddling I found the solution:
1. Press 'Menu' button. You will see 'Menu' written in Russian. To the right you will see a number '1' above the the word 'TV' or 'Video'. This is 'Menu 1' or screen 1.
2. Press ONLY the 'Menu' button and the arrow on the left will scroll down. On the fourth press the '1' referred to above will change to a '2' for 'Menu 2' or screen 2.
3. Continue to slowly press the 'Menu' button until 'Memu 3' or screen 3 appears.
4. Press the 'Menu' button twice more and then use the first channel changing button to change the language from Russian to English.
Apr 02, 2010 | Grundig GF70-600 TV
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Menu, select buttons not working
Try getting a universal remote that would let you get into the menu and change the settings you are thrying to change.
Jan 02, 2006 | Zenith Z46Z83D 46" Rear Projection...
189 people viewed this tip
 Grubhead
Grubhead
