Tip & How-To about Microsoft Windows Vista Ultimate Edition
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Microsoft Windows Vista Ultimate Edition Logo
gateway login
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both.
Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page.
Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make.
Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 18, 2013 | Computers & Internet
enter password unlock system
Log on as usual.
Method 2
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html
Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html
password cracker free
May 03, 2013 | Gateway 504GR PC Desktop
Hauppauge ImpactVCB 166 make setting default to S-Video
it should just be a setting under options in the driver controll panle for the video card
the next way is probly above your technical abilities
if you care to try here is how
find the folder in programs files if not there check in the main c drive
once you find the driver folder for the video card you have to find the file that controls the settings
mostlikely ending in .ini
if your lucky it will be a simple text file that you can open with notepad
your going to have to do some research on what the proper wording is to make the setting defult to s-video
who know it might be just that simple
you could also try the registy approach and change the setting in the registry that says what the defualt is saposed to be this method is the fastest and esayest way it is also the proper way if the setting is unavalible from the video cards controll panle.
the hard part is finding the corect registry entry to edit or modify
to get into the registry
start/run/enter in the field "regedit" then click ok
the registry editor should now be open
be highly advised making mistakes in here can and will corupt your system to the point of not working at all
if you dont know what the hkey is for dont tinker with it you will be sorry if you do
export any key you plan on changing befor you change it thus if you do make a mistake you can simply double click the exported hkey to restore it back to its original state
note for some Hkeys this wont be a fix it because your system wont even boot after you corupt the Hkey
good lucky making the change you need to make and check the setting of the card driver first look for tabs and sub menues boxes that say advanced on them check thru those first
Feb 24, 2010 | Computers & Internet
I cant get in to my screensaver settings, when i right click my desktop click on personalize then try to click on screensaver nothing happens and then everything sort of freezes i have a toshiba u405-s2820
This is only for XP and 2000. Also, try to change your desktop background before you use this information. The option to change the background is on the same screen as the screensaver settings. The tab says background instead of screensaver.
Download cleandesktop (http://thespykiller.co.uk/downloads/cleandesktop.exe)and save to your desktop. (right click save as)
Double-click on the cleandesktop.exe it will automatically extract to c:\desktopclean
Then it will automatically run the cleandesktop.vbs script.
It will then kill explorer. You will temporarily lose your taskbar and desktop .
It will then repair the registry entries returning your normal desktop and context menu functions.
It will then restart explorer. Your desktop will be shown again once you have performed the cleanup
Each of the other users on the system needs to be signed in to clean up their desktop and regain the right click.
Another vbs is included to do this. It is named "other profiles regfix.vbs".
Have each user sign in and run other profiles regfix.vbs.
Go to start > run and type: c:\desktopclean press enter double click on other profiles regfix.vbs
Explorer will be ended and that user's active desktop registry entries will be repaired.
Explorer will be restarted. To restore the desktop to whatever picture you normally have, right-click on a blank part of your desktop, select properties > desktop tab & select your preferred picture.
Press apply & then ok to exit and then press f5. (to refresh) you will need to do this step for every user account.
Thanks
Jul 24, 2008 | Computers & Internet
1,042 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
