Tip & How-To about Computers & Internet
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
Computers & Internet Logo
forgot windows password
Well, forgot Windows password? It is better to take Windows Password Unlocker to do so, which is well-recognized to reset Windows password in a short time. You can prepare a bootable CD/DVD or usb to create a password reset disk, and then reset the password with ease.
Mar 07, 2012 | Computers & Internet
forgot mypassword
If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick:
  1. Log on to Windows by using an administrator account that has a password that you remember. You may need to start WinXP in safe mode.
  2. Click Start, and then click Run.
  3. In the Open box, type “control userpasswords2′, and then click OK.
  4. Click the user account that you forgot the password for, and then click Reset Password.
  5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Dec 17, 2009 | MSI Wind U100-016US Laptop
administer password
If you have windows XP, boot the computer in safe mode. When you start the computer keep tapping the F8 key to the advanced boot menu. Select safe mode. It would give you the login screen. Select Administrator, do not enter any password, if you can get through, it means that you did not setup a password for the system administrator. Once you get to the safe mode window with the icons, you go to start, control panel, user accounts, select the user account that you used to login and delete the password. You can retype a password again and exit out of the window and restart the computer. You would be good to go.
If you have windows vista, and you have created the password reset disc, you can use that to reset the password. You need to boot the computer with that disc. if not, you need to run the system recovery on your computer.
May 30, 2008 | Compaq Computers & Internet
192 people viewed this tip
David Payne
David Payne
