Tip & How-To about Audio Players & Recorders
How to clean a rear projection tv INSIDE
This is what I did and it worked great-
I have a 60" Phillips bigscreen that has been getting dusty and actually had a spider inside the tv for about 6 yrs. This bothered me a lot until I got the guts to unscrew the back covering (the large dark grey turtle shell type plastic cover). It came off very easily.
1. I made sure the tv was unplugged
2. once inside I could see all components easily
3. I rolled it outside onto my deck
4. I used my leaf blower to instantly remove all the clumps of dust and webs followed by a once over with my swiffer
5. I then used a soft glasses cleaner cloth to fine clean each of the 3 colored lenses
6. a damp soft cloth was used to clean mirror
7. replace the back cover and go! It made a huge difference in picture quality
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and is there a danger of shock even if the TV is unplugged?
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
60'' Mitsubishi bigscreen will not power up
this could be a lamp our a ballast issue
regards
Dec 12, 2009 | Televison & Video
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
163 people viewed this tip
 Grubhead
Grubhead
