Tip & How-To about Audio Players & Recorders
Box t eurovox or digivox
Firstly be more helpfull on the type of box you have if you have loaded the latest firmware or not is it a cable box terrestrial box or sattelite box this info is most helpfull when trying to answer these questions step 1 you must first down load the latest firmware for the box you have if you download the wrong firmware you will corrupt the box or what they term as brick it step 2 after you have down loaded the firmware connect the box to your tv set and aerial/cable/dish these are connected with what are commonly known as F fittings step 3 scan your box you should have a manuall to explain how to do this for the box you are useing step 4 after you have completed the scan you must turn the emu on .on the box you are scanning step5 example if it is the boxT you scanned go to menu press 1570 this then opens a hidden menu on the very bottom you will see key emu left or right press on the > < to turn the emu on after you turn the emu on press exit exit back to main screen you should at this stage have everything working if not redo step 2 on again HINT if you cannot access the hidden menu then you have not installed the latest firmware you cannot access the emu without the firmware been loaded first right hopefully you have all this done and you have your channels happy viewing last hints for you BOX T access code is 1570 .. EUROVOX access code is 1969 ...DIGIVOX code is 1004 now hope this helps
i need code for digivox my box has went of
if your on cable then i am afraid that slowly but surely they are blocking these boxs if you are on terrestrial then just input the latest or last keys and all should be ok
May 06, 2010 | StarTech.com StarView SV211K 2-port KVM...
My digivox has lost nearly all channels apart from freeview options nd sky sports 1-4. All movies nd espn gone. I've tried rebooting box,checked emu1004 nd changed frequencys back nd fourth but now back to originals,any ideas?
if its a cable box then sorry there is no fix for this problem yet if it is a terrestrial box then delete the scrambled channels and rescan if you factory reset the box then you must install the latest firmware
Apr 26, 2010 | StarTech.com StarView SV431USB 4-port KVM...
most of the channels on my starview box are not working. can anyone tell me what the problem is?
You should have received a new card from your subscriber once you insert it you should get your channels back..its the only way you will get channels back..
I just did mine today after having nothing and it now works
Apr 24, 2010 | StarTech.com StarView SV211K 2-port KVM...
box super usb
there can be many reasons why you have blank channels can you supply us with more info ie.type of box sat. terrestrial cable have you downloaded the latest firmware have you turned the emu on and most important is if you did download the firmware was it the correct one for your box
Apr 22, 2010 | StarTech.com StarView SV431USB 4-port KVM...
dvd recorder hard drive DVDR5350H
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
Oct 03, 2008 | Televison & Video
964 people viewed this tip
 Grubhead
Grubhead
