Tip & How-To about Maytag MDB8959AW Builtin Dishwasher
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
Maytag MDB8959AW Builtin Dishwasher Logo
the wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The lights are blinking and I can not turn on the dishwasher.
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Jun 22, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
CLEAN LIGHT IS FLASHING SEQ OF 7 FLASHES THE LAST TIME TECH CAME OUT AND RESETUNIT, WE TRIED TO RESET AGAIN BUT NO HELP. ANY IDEAS
The cause of the problem is an insufficient rise in water temperature during a pre-set time period. The heater fault-detection program that was added to the electronic control is designed to shut down the dishwasher if the board-test for proper water temperature rise is not sufficient.
You will need to identify possible causes of insufficient temperature rise. These causes may include checking the wiring to/failure of the control, the heating element, the thermistor, the inlet valve, door switch, motor or capacitor. Make sure that water is not siphoning during fill. Once the heater fault detection is triggered and the condition resolved, the electronic control must be reset by initiating a special diagnostic cycle. Use the Product Tech Sheet shipped with each dishwasher — you’ll find it behind the kickplates — to identify the correct cycle sequence. The rapid advance cycle will not properly reset the electronic control.
Sep 25, 2009 | Whirlpool Dishwashers
dishwasher wont start washing but start light is flashing 11 times
hi...
The dishwasher run cycle was modified to add 8 minutes 45 seconds of heat at the beginning of the main wash cycle. If the inlet water at the thermistor is below 110°F, the thermistor looks for a water rise of 4°F. If the inlet water is over 110°F, the test is for an increase of 2°F. If the temperature rise is below specifications, the unit will drain and the clean light will blink seven times.
You will need to identify possible causes of insufficient temperature rise. These causes may include checking the wiring to/failure of the control, the heating element, the thermistor, the inlet valve, door switch, motor or capacitor. Make sure that water is not siphoning during fill. Once the heater fault detection is triggered and the condition resolved, the electronic control must be reset by initiating a special diagnostic cycle. Use the Product Tech Sheet shipped with each dishwasher — you’ll find it behind the kickplates — to identify the correct cycle sequence. The rapid advance cycle will not properly reset the electronic control....
thank u
rate me
Jul 22, 2009 | Dishwashers
14,080 people viewed this tip
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
