Tip & How-To about Dishwashers
Poor cleaning or noisy pump on Whirlpool or Kenmore dishwasher?
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
More dishwasher links
flashing_or_blinking_green_clean_light_7
general_dishwasher_cleaning
Hard_water_calcium_white_powder_build_up
Dishwashers Logo
detergent opener does not dispense detergent during wash cycle. ive tried washing 4 different times and detergent sits undissolved in dispensor. dispensor door does not pop open either when i open door after wash cycle is done.
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned.
Here are instructions that might help.But not knowing your specific model these instructions may not apply
Feb 14, 2011 | KitchenAid Dishwashers
Flashing or blinking green clean light 7 times?
Great! Thank you! Maytag won't answer during the weekends...
Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
the wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The lights are blinking and I can not turn on the dishwasher.
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Jun 22, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
13,948 people viewed this tip
Top Dishwashers Experts
