Tip & How-To about Computers & Internet
AOC monitor Lock-Unlock instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Computers & Internet Logo
its all in chinese/japanese
You can change the language
  1. Press the MENU-button to activate the OSD window (Figure 4).
  2. Press or > to navigate through the functions. Once the desired function is highlighted, press the MENU-button to activate it. If the function selected has a sub-menu, press or > again to navigate through the sub-menu functions. Once the desired function is highlighted, press MENU-button to activate it.
  3. Press or > to change the settings of the selected function.
  4. To exit and save, select the exit function. If you want to adjust any other function, repeat steps 2-3
move over to the l6vg3rvxxz8ymgoa4yod79+9fuuhambiudvzz+g2uz9sfm8tmswaaaabjru5erkjggg==icon press the menu button press to select English Press Menu button
select the exit icon which is the right bottom icon press menu to save
Jun 19, 2011 | AOC LM729 17" LCD Monitor
Osd Lock how to open?
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
7,765 people viewed this tip
David Payne
David Payne
