Tip & How-To about Cisco 2610XM Router
How to divide bandwidth using cisco routers
The Bandwidth command's real purpose
First, let's discuss the real purpose of the bandwidth command. In the above scenario, the questioning administrator didn't understand the true purpose of this command, incorrectly assuming instead that the network would receive the bandwidth configured with the command.
The bandwidth command is only there to communicate the speed of the interface to higher level protocols. Most of the time, a routing protocol needs to know the speed of the interface so it can choose the best route.
In the case of routing protocols, IGRP, EIGRP, and OSPF all use the bandwidth statement. However, TCP will also adjust its initial retransmission parameters based on the bandwidth configured on the interface.
OSPF uses cost as its routing metric, which it calculates using bandwidth. For example, OSPF takes 108 and divides it by the bandwidth of the interface. To calculate the cost of a full T1, OSPF divides 100,000,000 by 1,544,000, which returns an OSPF cost of 64. (Cisco routers don't use floating-point math, so they drop the numbers after the decimal.)
On the other hand, EIGRP uses the bandwidth of the link to calculate its routing metric. Here's the EIGRP metric formula:
metric = [K1*bandwidth + (K2*bandwidth)/(256 - load) + K3*delay] * [K5/(reliability + K4)] We won't try to calculate a metric in this article, but as you can see, the process definitely requires using bandwidth. In fact, due to the default K values, the only values used to calculate the EIGRP metric are bandwidth and delay.
Examples You configure the Cisco IOS bandwidth command on interfaces. Here's an example:
interface Serial0/0 bandwidth 128 ip address 1.1.1.1 255.255.255.0 This command has only one option—the bandwidth, in kilobits, of the interface.
Router(config-if)# bandwidth ? <1-10000000> Bandwidth in kilobits Router(config-if)#bandwidth There are always default bandwidth values set for each type of interface, such as the Serial interface, as shown below:
Router# show interface s0/0 Serial0/0 is administratively down, line protocol is down Hardware is PowerQUICC Serial MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, In the case of a serial interface, the default bandwidth is 1,544 K (or a full T1 circuit). However, you could have a fractional T1 circuit, and the default may be incorrect.
As you can see, setting the correct bandwidth on each interface is very important when it comes to routing protocols choosing the right router. However, no matter what you set the bandwidth command to, you won't actually get faster throughput out of any interface—the two simply aren't related.
Cisco 2610XM Router Logo
The picture on my tv sticks but sound carries on why
Most likely you are watching a digital channel. If so, it could be the bandwidth from the digital connection is to small. Your internet connection, needs to have enough bandwidth for steaming video. It could be your provider delivers enough bandwidth, but your LAN (wireless most of the time) is trothing. Sometimes providers don't like you to stream TV and will slow video streams deliberately.
Enough possibilities to start searching for the real cause in your house.
Feb 24, 2015 | Televison & Video
Bandwidth Explained!
You can get the Unlimited Hosting Plans with Bandwidth etc..In the site http://www.tucktail.com/ at low cost..
Dec 28, 2009 | Computers & Internet
what command will show the maximum bandwidth a
The command is : bandwith ?
will show you the maximum bandwith
Jun 23, 2009 | Cisco 7505 Router
Motherboard Drivers
What make is your motherboard? If you open up the case and there should be info and model number on it. The just go to the makers website a get appropiate drivers.
hope that helps :)
Dec 29, 2007 | Computers & Internet
1,736 people viewed this tip
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
