Tip & How-To about Audio Players & Recorders
How to increase your subwoofers base?
The one thing you need to do is to make your subwoofer alot mor louder is to vacuum it through the hole. Now it should be louder.
bad gears on lindy's popcorn popper
IF they don't fit well together, you may need to file them smooth, or use it alot to get them to wear together better.
It one broke off then consider drilling a hole in gear and tapping a set screw in place to hold it.
See the Comments at Amazon.com for mor suggestions on repairs for this exact model.
Sep 22, 2013 | Lindy's Stainless Steel Stove Top Popcorn...
can noisy Hydraulic roller lifters eventually turn into a loud knock. 4.0 motor
Possible. I have replaced the roller rocker arms and push rods because they get clogged and wear out both parts. I guess if left to long they would punch a hole threw the arms and knock alot louder.
Jul 21, 2011 | Ford Ranger Cars & Trucks
frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Polk PSW 303 subwoofer emits a hum when plugged in and powered off. When the unit is turned on the hum gets louder. At this point the unit is useless. Does anyone know what could be causing this?
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
Jul 16, 2009 | Polk Audio PSW-303 Subwoofer
Hoover F5906-900 motor sounds very loud.
Bearings in the motor are bad, you will have to replace the motor.
Nov 09, 2007 | Hoover F5906-900 Upright Steam Vacuum
191 people viewed this tip
 Grubhead
Grubhead
