Tip & How-To about Computers & Internet
Restoring Missing CD/DVD drives from my computer
The cd/Dvd drive has disappeared from windows explorer and system folder "my computer " A glance in the device manager shows that obviously there is some serious problem .the entries are marked with a yellow exclamation marks .This is also confirmed by opening "properties' in the context menu of the device ,it reports "error code 19"an error has occurred in registry .
This kind of problem can be solved by changing some entry in registry .open registry editor with "start" "run" in run type regedit and click "ok" and go to Hkey_local_machine>system>current control set>control class>{4D36E965-E325-11CE-BFC1-08002BE10318} in the right side of the window,delete both the values"uper filters"and "lower filters".To do that select the successive entries press (del),and confirms the security query that will pop.After restarting your system the drive will be back again.
Computers & Internet Logo
my cd-rom location do not show up on my Dell Dimension 8250 computer devices. Why
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
hp pavilion dv 6910us with windows 7 ultimate 64 bit doesn't recognize my installed dvd rw drive by pioneer model kd08... sometimes it will appear in devices with removable media but will later disappear...
this could be a registry issue
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 08, 2011 | Pioneer DVR-KD08 DVD±RW Dual Layer Burner
new computer {emachines desktop} cd/dvd drive does not work and does not show up on device listing.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 24, 2011 | E-Machines emachines (emachinees) CD-ROM...
my dell studio 1737 doesnt read any disk when i put them in
HI Friend, In this case I would recommend you to check if the CD/ DVD drive is getting detected in Windows Explorer or not ( MY computer) window. If it is not getting detected there then goto device manager and check if you have yellow bang on the CD/DVD drive option or not. If there is a yellow bang then you need to follow the below steps:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation anderror code on the CD or DVD drive is gone
### If CD/1) Close all open programs 2) Click on Start, Run, and type REGEDIT and press Enter
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
### IF CD/DVD is getting detected in windows explorer then try updating the firmware for CD/DVD drive
Dec 14, 2010 | Dell Studio 1737 Laptop
cd/dvdrw drive disappears
try booting in safe mode and see it comes up then
Mar 08, 2009 | Toshiba Satellite A45-S250 Notebook
243 people viewed this tip
David Payne
David Payne
