Tip & How-To about Computers & Internet
Running maintenance tasks while logging on and off
The tool you need to use is the group editor ,which is a part of the win xp and vista .In Xp start the group policy editor by clicking start >run >and type gpedit.msc .To Run a script when a user is logging on or off select local computer policy < user configuration >
Computers & Internet Logo
cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
---> System
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
System Restore gets disabled
You must set the "Service" to "Automatic" here are some instructions. And a link to a M$ KB article about it. support.microsoft.com/kb/302796 Start the Group Policy Editor (gpedit.msc) Navigate to Computer Configuration/Administrative Templates/System/System Restore Set Turn off System Restore and Turn off Configuration to "Disable" Right click on My Computer and Select "Manage". Navigate to Services and Applications/Services Navigate to System Restore Service and double click On the General tab set [Startup Type] to "Automatic" using the drop down list Click the Start button to start the service. Close the Computer Management console Return to System Restore in Group Policy Editor and configure both to "Not Configured" Close Group Policy Editor and reboot the system. After the reboot is complete, right click My Computer, select Properties and the tab for System Restore will have been restored. Configure it to your individual needs.
Aug 20, 2007 | Microsoft Windows XP Professional With...
169 people viewed this tip
David Payne
David Payne
