Tip & How-To about Televison & Video
No matter whats wrong !!!!!!!
As a repair tech its hard to find (track and trace) faults some jobs take hrs and thats with the unit inside the workshop so imagine how hard it is to diagnose the problem on a computer screen i love being able to help people the world over but when it says (help no power) its pritty certain youl not get a reply as what can we do when you explain whats wrong tell all you can go mad write every little thing you can think of as the more we know the more we can do to assist you in fixing it your self
sonic boom electronics
Televison & Video Logo
how do i Fix a timing belt oin a TK Holden Barina
The fix on the car is by replacement only. It is recommended that during the belt change any oil seals ( cam and crank) , hydraulic tensioners and idler pulleys are changed also. If the job is done correctly you will get another 100.00klms for the new belt but if you take short cuts and just do the belt then reduce the expected life of the belt to 1/2 that. The cost if done by an accredited workshop will be from $600 to $900 and will take about 5 hrs. Get quotes from recommended shops with a proven track record.
Oct 11, 2014 | Cars & Trucks
Fault = Tracks Missing??? What does this mean?
did you enclose the bill of purchase when u sent the phone?? what is the phone upto now?
Sep 25, 2008 | Samsung SGH-G600 Cellular Phone
what tool needed to remove the front axle on a audi a4
The usual car repair workshop tools can be, like, a large wrench, screwdriver, but if you're not car repair shop, then it is best to repair shop, it need professional tech. any questions, pls ask the 24 hrs live technical support wiTECH VCI Pod, they will like to help you, good luck
Sep 03, 2013 | Tools & Hardware - Others
Panasonic DMR-ES36V I was recording a VHS to DVD and the tracking went out of wack... Now any VHS I play it wont track properly. Any ideas? I have tried the tracking button and no luck. Again it doesnt matter the VHS I put in it, it still doesnt play correctly... Help
Being a VCR/DVD recorder combo unit, the tracking issue is usually mechanical, and can be caused by any one of a number of things, including guides.
Unless you are tech. savvy with years of experience, this repair really should be undertaken by a qualified technician in a fully equipped service workshop, as some of the parts, if they need to be replaced, can only be obtained via them. The other worry is the expense.
In your case though, it sounds very much like a faulty guide (some service agents refer to these as 'base incline units') assuming the playback picture has noise bars but the speed is otherwise steady - replacement/alignment should be done by a technician - submit your unit to a workshop, tell them the problem, get a quote, and second opinion on the likely parts/labour costs involved, then make a decision afterwards on what action to take. Up to you.
(these decks use a belt between the capstan and the clutch flywheel under the mechanism - the workshop may replace the belt as well, since these stretch over time; which can also cause tracking issues)
In any case, the workshop second opinion and quote will tell you more. You should not need a new unit.
Jun 19, 2011 | Panasonic DMR-E55 DVD Recorder
I need to repair the power socket, how does the case come off?
The DC harness on this model is a known fault. Toshiba UK will repair this power harness free of charge even if the unit is out of it's warranty period. I see yours is the US unit but I would imagine it is a free service over there too. Contact Toshiba customer support, explain the DC harness is loose inside your system and ask if it is a free repair due to being a known fault on that range of laptops. Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite L305D-S5895 Notebook
200 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
